Stock ride height? (from hub to fender)
  • cbusrehab
    • May 2008
    • 90
    This is somewhat of a unusual request. I'm switching to coilovers and am trying to figure out what the stock ride height (measuring from the fender to the center of the hub) is front and rear on an e30. I would like to start the coilovers by setting the ratio the same, front to rear, as stock ride height and adjust from there. The suspension that came on my car has quite a rake on it and more of the weight distribution on the front then it was from the factory.
    Thanks in advance for any help.
    • 34847
    it actually depends on the car... year, engine, options (AC), etc.
    • cbusrehab
      • May 2008
      • 90
      yeah i forgot that part, its for a 1991 325i with A/C with stock m20. I know that it will vary from car to car but anything is better than what I'm starting with now.
      • 36brua
        • 689
        get your bentley out. it has dimensions measure from bottom of wheel to wheel arch. rear wheel
        My CA legal M60 swap
        The happening in our garage
          The way to do this is to put the car on a set of scales and tweak the coil overs for good front to rear weight balance and the best corner weights you can get.
            • 34847
            that doesn't work if you have different sized wheels from stock.
            • cbusrehab
              • May 2008
              • 90
              I could probably use a ratio if I had the front and rear measurements, but the bently only has the front measurement which doesn't really help.
