Weird issue
  • rabbitude
    • Jan 2010
    • 247
    Weird issue
    I am having a weird problem with the front suspension on my car. The car drives straight and perfectly on a level road but whenever I drive over uneven road, even more so at low speed the car pulls to either side. It feels exactly like torque steer in a front drive car, I have to grab the wheel firmly to keep the car straight. The car seems to folow ruts in the road. I have owned a bunch of other E30's and never had this problem. Heres some basic specs on the car
    H&R race, billies, UUC camber plates, cabrio 21mm front bar and IE 19mm rear.
    Any ideas on what could be causing this.
    070 by wonderwilley, on Flickr
  • e34john
    • Apr 2006
    • 3599
    What tires do you have? Wider and stickier tires and lower profile tires will do that, they like to tramline.
    • IDM
      • 754
      Isn't that what people call bump steer? if the car is too low with no correction in steering geometry the car will do that.
      • dranttna
        • 127
        also if your sway bars are to stiff for your spring rate its will cause this, but with the h&rs it shouldnt cause too much
        325es/24v's/20psi/meth injection/
        • ak-
          • 12422
          I have the same problem as you.
          1991 325iS turbo
          • b*saint
            • 3794
            Lowering the car causes that.
            Ma che cazzo state dicendo? :|
              What is the condition of the front and rear suspension (control arms/bushings, tie rods, RTAB's, and subframe bushings)? What is front camber & toe set to and do you have offset CAB's? Have you checked the camber and toe on the rear wheels?
              A lowered car in general, but especially in this configuration, is more sensitive to minor flaws in the suspension. The cause of this could be the front suspension, rear suspension, or a combination. My guess right now is that the rear camber and toe are not the same left to right and you are getting camber thrust. But that is just a guess.
              • rabbitude
                • Jan 2010
                • 247
                The rear of the car was in perfect alignment when I bought the car a few months back. To the best of my knowledge all the components of my suspension are pretty new. The only thing I can think that may be causing this is the camber in the front. When I had the springs and shocks put in the guy set the toe but did not have time to set the camber. The front camber is set at almost 3 degrees, I just ordered a set of drop hats and was planing to set the alignment properly when I get those in.
