Bumpstop question/ Bilstein HD Rear
  • Stephen
    Шлем ишака
    • 10774
    This thread makes me happy. Ive been searchin awhile, mostly pretty vague answers so far.
    • Van Westervelt
      • 9365
      Glad I could be of service sir.
      • Stephen
        Шлем ишака
        • 10774
        <3
        Will be doing this over break
        • sticksdaman
          • Apr 2005
          • 2987
          Seriously,
          If we had a REP points system, you'd SO be repped. I cant tell you how long ive been searching for answers to this question but to no avail.
          Originally posted by ebelements
          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          • Van Westervelt
            • 9365
            No prob. Just dont cut off more than an inch or so! Otherwise havoc will ensue inside your strut tube.
            • E30SPDFRK
              • 5709
              What I'm not understanding is where the shaft goes. My struts are completely bottomed out and the shaft is pretty much fully inside the housing. By shortening the bumpstop, wouldn't the shaft go too far into the tube?
              Byron
              Leichtbau
              • Stephen
                Шлем ишака
                • 10774
                Theres a pic of hellabad bottoming out struts with his own weight somewhere on here, and theres still plenty of shaft showing.
                • E30SPDFRK
                  • 5709
                  Maybe the ix struts are different then, because I have about 1/4" of shiny left sticking out.
                  Byron
                  Leichtbau
                  • Van Westervelt
                    • 9365
                    No no no, you dont bottom them out to remove it. You put the nut on the top, flip it upside down, then smack it into the ground. Should pop out the bottom after a couple smacks. If you bottom it out, you are just pushing it onto the bump stops and wont get anywhere.
                    • Van Westervelt
                      • 9365
                      Thats why you only cut 1" off. Anymore and you are going to wreak havoc on the internal bits.
                      The shaft you see in the pic is on the bottom of the strut in the tube.
                      • E30SPDFRK
                        • 5709
                        No I'm saying that with weight on the car there is only 1/4" of the strut shaft sticking out. If I was to shorten the bumpstops an inch, wouldn't that put my shafts too far down in the tubes?
                        Byron
                        Leichtbau
                        • Van Westervelt
                          • 9365
                          Its not lowering your car more by cutting them. Its allowing the shock piston to travel 1" more overall from the bottom.
                          • Stephen
                            Шлем ишака
                            • 10774
                            I was just referring to the pic, which shows that a 1" cut should be fine
                            • E30SPDFRK
                              • 5709
                              But what I'm saying is when the shaft travels that 1" lower, like driving over bumps, wouldn't the shaft go too far inside the tube? Since I only have 1/4" of shaft sticking out when the suspension isn't compressing.
                              Byron
                              Leichtbau
                              • Jean
                                • 18228
                                Yes, it will void the warranty. You push the shock tube out of the sleeve through the bottom. Then you cut no more than 1-1 1/8 inch off the top of the bumpstop. Then press the bottom plate back into the yellow sleeve. Rides like normal, but the shocks have another inch of usable travel.
                                Do they (Bilstein) offer this service for new shocks?
