source for 21mm sway bar bushings?
  • funcrew
    • Jun 2007
    • 1223
    I'm trying to install a used 21mm cabrio front sway on an '88 sedan. All the suppliers have the one-size-fits-all end links, but I'm having a hard time sourcing 21mm rubber bushings, only the 20mm is listed. Any ideas?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • Jean
    • 18228
    The end-links are the same, no?
    I am sure Blunt or your local dealer can get you 31351132355 bushings.
    • Lunner
      • 222
      I got mine from www.bmpdesign.com
      And yeah, they cost way too much IMO ($40+shipping), but they were the only source I found after quite a bit of searching.
      If there's a cheaper option I don't wanna hear about it now, hah.
      Edit: They were poly's, if that helps.
      87 325iC 90 325iC 88 325iC 87 325i 87 325iS 87 325eS
      • funcrew
        • Jun 2007
        • 1223
        Thanks - I was looking for OEM rubber to match my poly-free suspension theme.
        -Dr. Paul Forrester
        • Lunner
          • 222
          I went for rubber 99% of the time too, but I just couldn't find it in this case.
          • funcrew
            • Jun 2007
            • 1223
            Thanks - I confirmed this P/N on realoem.com and got the bushings from pelicanparts.com for $30 shipped.
            -Dr. Paul Forrester
            • lateracer
              • Sep 2009
              • 302
              NICE! Been looking for these. Glad Pelican has 'em.
              Thanks for the info
              • McGyver
                • 4595
                blunttech.com can get them for $12.11 each, where as the dealer is alot more. his are OEM by the way.
