Tie Rods
  • E30_fiend
    • Apr 2006
    • 7348
    Tie Rods
    I have been wondering lately. I know my balljoints are toast on my tie rods and I plan on replacing them. What I was wondering is if it is needed to change the whole assembly. Or can I just change the tie rod end and be done with it? I guess a more direct question would be: what are the benefits of changing the whole assembly over just the rod end?
    Also, I seem to have no in or out play on the assembly where it goes into the rack so thats a good sign. This is what makes me want to change just the rod ends and call it a day.
    let me know guys
    Taylor
  • StereoInstaller1
    GAS
    • 22679
    Taylor, why do you think your tie rod ends are bad?
    balljoints are on the control arms, not the tie rods, even though technically they are actuaLLY A BALL JOINT, NO ONE CALLS THEM THAT.
    godddamn caps lock
    Closing SOON!
    Thanks for 10 years of fun!
    • E30_fiend
      • Apr 2006
      • 7348
      Luke,
      when I grab the rotor at 9 and 3 o'clock and push in and out I can see the ball joint moving and I can hear it moving as well. I know they are bad. But anyway I need a tie rod end, not a tie rod ball joint
      Taylor
        Best practice is to replace the entire tie rod. While most of the wear may be on the outer ball joint, there's probably significant wear on the inner joint.
        • StereoInstaller1
          GAS
          • 22679
          Once again, Jim nails it
          Closing SOON!
          • E30_fiend
            • Apr 2006
            • 7348
            Thats the answer I waned to hear
            • McGyver
              • 4636
              so by just replacing the outer tie rods i did a bad thing?
              • E30_fiend
                • Apr 2006
                • 7348
                I wouldnt say that but replacing the whole thing is just as easy and it only takes a little more time and money
                • lonestar22
                  • Aug 2005
                  • 417
                  i say replace the whole thing. its faily easy and it will make your car feel alot better
                  Originally posted by Lof8
                  Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
                  • E30SPDFRK
                    • 5715
                    As long as there is no play on the inner it's perfectly fine to just change the outer.
                    Byron
                    Leichtbau
                    • ak-
                      • 12422
                      I have a GOOD inner tie rod, but lousy outer end in my trunk if you want for a few bucks.
                      1991 325iS turbo
