So far still only UUC and kmac camber plates confirmed to work?
Drop Hats.....
quick question regarding e90 drop hats. The e90 haps have metal ring on the bottom of the center hole, while the bottom of the e30 tophat is completely flat. When installing the e30 hat does that ring on the bottom of the e90 top hat affect anything? I just find it hard to believe that the e90 hats can drop the car 10mm's with that ring in there. Do you still leave in parts 7 and 8 in the picture below?
Special Agency
Originally posted by spiDmang View Posti would say it would be a great idea to use with coilovers. you get the needed drop from the drop hats, but can also keep preload for the spring. many coilover companies say its important to keep preload if you want to have a somewhat comfortable ride.
there's definitely no point to using a drop hat with a coilover spring, that doesn't (and can't) use the stock spring perch in the first place..
I'll assemble an IE camber plate with drop hats tomorrow to see how it goes. Just bought the hats on a whim.I don't always wreck cars, but when I do I wreck them into trees.
91' 318is S50 swap - The Black Widow
Originally posted by TimKninja View PostJust picked up a pair from the dealer. $12 each. Im using them on Jom Coilovers. Kinda pointless i know.
Originally posted by CabbE30 View PostI have a knocking on the passenger side after putting on my e90 strut hats. The spring must not be seated correctly or the top strut bolt isnt tight enough? Anything else I should check?
Yes JOMs should work with drop hats. The top of the spring is the same diameter as a stock spring, and it seats in the stock spring hat and strut mount.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP)
