What am I missing/what do you think of this shopping list? opinions wanted
  • Sagaris
    • Sep 2009
    • 2243
    my 186k mile 325i is just about ready for its stock suspension to be swapped out. This is what I have in mind. Call me a sheep for going H&R/Bilstein/Suspension techniques but I trust that Turner has reason for putting those items together Please let me know if you have any suggestions on things that I am missing/should add I would love to hear them.
    Front Bushings: Stock E30 M3 offset bushings $39.50 (Turner)
    Front Control Arms w/ balljoints: Meyle $159.00 for both (FAP99.com)
    Brackets: $62.50 (FAP99.com)
    Front suspension mounts: $99.50 (Turner)
    H&R Sport +Bilstein kit $639.95 (Turner)
    Susp. Techniques sway bars F:22mm/R:19mm $339.95 (Turner)
    Rear suspension mounts: "repair shop"whatever that means $39.95 (Turner)
    Are there any small items that I am missing?
    I would love to save a little bit of money if I could. I am already saving a bit by getting what I can from FAP99.
    I'd use Lemforder control arms rather than Meyle. The Lemforder arms are more expensive, but have a reputation for lasting, unlike the Meyle arms.
    "Brackets: $62.50 (FAP99.com)" What are these?
    You'll need to weld in reinforcements on the rear sway bar pickup points on the trailing arms. The reinforcements that Turner sells are far superion to the flat plates furnished with the sways. I personally think that the IE or UUC sways are better than the ST parts.
    • McGyver
      • 4495
      go with blunttech.com. steve's a member here and im sure he can get you the best prices. if you want the front lower search for the 15mm drop hats.
      • Sagaris
        • Sep 2009
        • 2243
        This is what I mean by "bracket"
        Is this what people refer to as "lollipops?"
        I requested a quote on the Lemforder arms, There are also Ocap brand arms for the same price as the Meyle. Do you have any specifics on the Meyle's not "lasting" When I searched I found a few threads on bimmerforums of people asking if Meyle are okay but didnt come to any real consensus.
        Thanks for the info so far, keep it coming!
        • Holland
          • Nov 2008
          • 7176
          Dude, did I ever tell you how much I love your sig with Danny in it.
          Originally posted by DEV0 E30
          • Sagaris
            • Sep 2009
            • 2243
            :D
            If I went with the H&R race springs I would have to add a caption saying "This suspension is hard as tits!!!!"
            • Sagaris
              • Sep 2009
              • 2243
              I HAVE 2 QUESTIONS!
              yes, that deserved all CAPS.
              1) Will I re-use the factory bump stops , do I need shorter bump stops, or I have heard someone say that you use no bump stops. What is correct?
              2) I know the rear subframe bushings are a PITA. what about the RTAB (rear trailing arm bushings)? If they are as straightforward as the front end bushings then I will do them as well.
              • drumad
                • Aug 2009
                • 1700
                The hardest part of rear subframe bushings is removing the rear subframe. Then again, after doing it once, its not hard now that I look back on it.
                both are easy, esp with all the home made tools people have posted online
                plus its like e30 owner initiation to remove your rear subframe
                2008 335i - n54b30
                1991 318i - m52b28
                1994 fzj80 - LAND CRUSHER
                • E30_fiend
                  • Apr 2006
                  • 7348
                  stay away from Meyle arms. pay for the good stuff
