Offset front control arm bushes??
  • ethrty
    • Nov 2009
    • 342
    so they correct castor.. but why would one need to 'correct' that?
    just looking at getting some new buxhes for the front and wondering what you guys would recommend.
    some relevant specs:
    daily driver, never tracked but spirted driving
    51mm struts
    lowered but not slammed
    currently 17x7s fwd offset but will be putting some 15 or 16x8 et0 on there (sportmax 002) eventually
    thanks for your reccomendations!
  • bimmer630
    • 1230
    Offset bushings dont "correct" caster unless you have some non-factory setup like a 5 lug swap or something.
    BMW used the offset bushings in the E30 M3 to gain additional caster.
    I had them in my E30 before I moved to the 5 lug setup and I would recommend them over the normal bushings, Increased caster will promote quicker turning/better handling
    • Van Westervelt
      • 9365
      With a stock setup, the caster change will give you better turn in. More responsive bite etc when you turn the wheel.
        Sorry, but that is backwards. Increased castor results in better directional stability at speed. Increasing camber and reducing toe results in more response when turning.
        • lifeiskaos
          • 1709
          When offset CAB's are added, you should probably get an alignment, right? Seems like they'd pull your struts in just a hair, causing some toe out?
          • bmw325csi
            • May 2007
            • 4045
            ^of course, any front end suspension work calls for an alignment
            harry/harout
            • Wh33lhop
              • 11705
              Positive camber, and toe out. I'm on stock suspension with M3 CABs and I've got positive camber.
              paint sucks
              • Wh33lhop
                • 11705
                Positive caster results in negative camber gain on the outside wheel when the wheels are turned. I'd say that's good for turn in, but it will affect you more in low-speed corners where the wheel will be turned further and more camber is gained.
                paint sucks
                • ethrty
                  • Nov 2009
                  • 342
                  i kinda knew what all the different alignment terms meant (thank you Play Station!) but i wasnt too sure whether they would be worth the money on a street car. think ill go for them if they arent ridiculously more than the OEM replacements. thanks guys!
