Riding on the bump stops
  • formula driver
    • 2263
    I have a question about Koni SA's. This is probobly gonna seem like a stupid question but I need to know the answer. I am using koni SA's in the rear paired with 650 lb GC's. I have my GC's set to the lowest position and my SA's are on the bump stop's. My springs are very stiff so theres not much room for compression as it is. But I need to know if it will be ok to drive this way. Will my koni's hold up or will they be subject to damage by being so compressed? Thanks for any help.
    • 34847
    if you are on the bump stops, then you have no suspension travel at all. you might not break the konis (i wouldn't bet on that), but the first time you go over a big bump you're going to mangle your upper shock mounts. why do you need it so low? I'd raise it up at least an inch...
    • Charlie
      kid tested, administrator approved
      • 6686
      :dot:
      Kind of hard for a shock to do it's job when it has zero range of travel. Think about this, if the shock isn't able to compress, then the spring doesn't compress, there is no "suspension" on the car now save for the subframe, diff and other mounting points.
      Translation: get ready to start breaking a bunch of shit.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • Jared K
        • Sep 2004
        • 58
        How do you know the Konis are on the bumpstops? Aren't the bumpstops obscured from view by the dust boots?
        • Charlie
          • 6686
          They're probably already blown.
          -Charlie
          FYYFF
          • formula driver
            • 2263
            Havent driven on them yet, so there not already blown. I have no dust boots but I can see only a couple of inches of the shock while im still lowering the car off the jack. When its setteled the rear tire tucks. I dont HAVE to Nando.. I may consider raising it. Thanks Charlie, I never considered those things.
