What if you pull the third nut off of the strut mount and lower the strut until the top of the studs are flush with the strut tower surface?
You could get into the engine compartment with your hands on one shock tower, your feet against the other, and push.
You could put a pry bar between the vertical portion of the strut bar and the shock tower.
I doubt that your frame relaxed so much that the tires were 1" of the ground one day and touching the ground the next day. Your jack probably lost pressure. Actually, I can't imagine that your frame will relax over time at all.
Jared K
Jared K
