What's the Best Sway Bar Set-up?
  • BeLzEbUb58
    • 112
    Suspension Techniques, Ireland Engineering or Swaybarian? All seem to have a 22mm front and 19mm rear. I have a 91 e30 sedan with HR Sport springs and Bilstein HD lowered 1.25".
  • Dirtbleed
    • 495
    I run IRE 25/22.
    • White325is
      • Oct 2006
      • 5947
      ^^ Same and I love them. Just wish the end links would be a little better.
      • KenC
        King of Kegstands
        • 14396
        What don't you like the endlinks?
        I run the same set and like them.
        Originally posted by Gruelius
        • fiftytakedowns
          • 2460
          stock
          [/url]
          Team USA Wrestling 67KG
          • M-technik-3
            • 18946
            Very vague question....what are you looking for? Flat car in turns and soft springs? Stiff springs thinner sways? or adjustable.
            • T Verdier
              • Aug 2007
              • 2636
              I dont see any reason to not get the IE 25/22mm ones they the thickest ones out there. And unlike super stiff springs they don't make the ride harsh.
              I have them and love them so far. Although I can't get the links short enough to make the bars flat like they should be.
              • BeLzEbUb58
                • 112
                The way my car rides is great, not too stiff or bone jarring, but I still feel too much lean in turns. I'm looking for value. I've seen ST combo for $350, 22mm front, 19mm rear. Not sure what the different combinations represent, bushings, links and so on, so I thought I'd ask here. I also have a strut tie bar which helps with front end stiffness. Just need flat cornering without being harsh, if harsh is the correct descriptive term.
                • T Verdier
                  • Aug 2007
                  • 2636
                  Correct me if I'm wrong, as I understand you can have super stiff sways and it won't affect you ride because it makes a connection between your right and left side suspension travel in relation to each other. So for instance if hit a train track both wheels will move up and down the same with or with out a sway bar.
                  The IE kit came with hiem joint adjustable links/ reanforcement tabs for the rear trailling arm/ poly bushings/ nice thick brackets with even more reanforcements for drilling into the trunk.
                  All that was about $440.
                  • M-technik-3
                    • 18946
                    Then you need to invest in some adjustable ones. I had to do the same when I added my ST/Jstock combo. So I originally went with Eli's that he sold. But they froze so I purchased some from TMS when they had a sale on them one day.
                    • JGood
                      • Jan 2004
                      • 7959
                      There are no "best" bars. It depends what you use the car for, your driving style, etc...
                      The typical kit is 22f/19r. For this, the UUC kit seems to be one of the highest quality, considering it includes Aurora adjustable end links and all of the reinforcements, including trunk reinforcements for the rear, weld on trailing arm tabs, and front subframe reinforcements. From what I understand, IE charges $100 more for their trunk reinforcements, and ST doesn't even offer them. I have the UUC kit, and it is great. Installation was a breeze, unlike stories I've heard about the ST kit.
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
                      • Dirtbleed
                        • 495
                        I run stock end links in the front.
                        • T Verdier
                          • Aug 2007
                          • 2636
                          So are your sways pointed upward at a 35 degree angle?
