How to increase front travel
  • rabbitude
    • Jan 2010
    • 247
    A few questions, I am running H&R Race, Billys, UUC camber plates, and 15mm drop hats. My problem is that I am hitting the bump stops more than I would like. I am afraid that I might waste my shocks eventually. Is there a way to increase the front shock travel a little to avoid hitting the bump stops as much. My car is not that low in the front and I dont want to raise it up. Will running stock upper mounts or GC camber plates give me a few more mm's. would it be bad to modify the bump stops. I don't know, any ideas.
    070 by wonderwilley, on Flickr
  • Omaliyo
    • 243
    Get ride of the 15mm drop hats????
    Slamburglars Handbook:
    5. Slamburglars don't get stuck on speed bumps, speed bumps get stuck on Slamburglars
    • theox69
      • May 2008
      • 1732
      You could modify the bump stops and get the GC camber plates.
      you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
      • E30_fiend
        • Apr 2006
        • 7348
        ^^^^this and you may want to cut your bumpstops as well as investigate how tall your camber plates are. most companies focus on adjustability and dont take into consideration the stack height. a taller stack height will lessen your shock travel as well as your 15mm drop hats.
        sounds like you have some reading/purchasing to do
        Taylor
        • E30SPDFRK
          • 5716
          GC camber plates actually give you less travel if you're just on springs.
          Cut a nub off your bumpstops. It's the only way to fix it other than raising it or getting shorter struts.
          Byron
          Leichtbau
          • rabbitude
            • Jan 2010
            • 247
            Is there any downside to cutting the bump stops.
            • E30_fiend
              • Apr 2006
              • 7348
              If you only cut one inch, absolutely not. If you think about it, the bumpstop is only there to soften the blow of a potentially horrible bump. If that bumpstop wasnt there, it would be a metal to metal thud which is no bueno.
              I have cut peoples bumpstops and havent heard a single complaint.
              • thebornotaku
                • 70
                Cut bump stops, and make sure you're running short struts so they're not compressed as far at rest, it'll be better for longevity.
                -Mike
                1985 Volvo 245DL "The Battlewagon"
                • rabbitude
                  • Jan 2010
                  • 247
                  Ok, stupid question but where are the bump stops are they inside the shock
                  • ak-
                    • 12422
                    Yeap.
                    Chisel off the bottom cap and a rod will pop out with 3 yellow bumpstops chilling there.
                    Looks like this:
                    [_)[_)[_)=================
                    Cut off the one I marked red.
                    Really easy.
                    1991 325iS turbo
