my buddy has a set of kyb struts and eibrach sportlines that were on his 240sx and he is selling them cheap. i was wondering if they would fit on my bmw 318i... opinion or suggestions please and thanks
shocks and springs 318i
Although the weight, wheelbase, and center of mass between an e30 and an S-chassis Nissan are not too different, I still do not like the idea of fiddling with the suspension which may create unsafe handling characteristics. Especially since E30's can give you some snap-oversteer if they are pissed off. Not to mention any rigging you may need to do if it doesnt quite match up.
If you really want to do it, I would compare the strut lengths,
compare the spring rates, length of springs, and the diameter at the spring perches. If the dimensions check out fine and the spring rate rear/front ratio is comparable to what is offered on an e30 then I would feel better about it.
