just ordered some Koni SA's, and was wonding if any of you with Konis leave the rear bump stops out so you can adjust the shock without taking it off. I'm guess if you leave it out you could just take off the bottom bolt and push the shock up and twist it to the desired stiffness and then tightest the bottom bolt back without taking the upper mount out... this would be way easier than having to take the shock and upper mount out to change it every time.
but I don't know if taking the bump stop out is a good idea or not, Heck, I don't even know if you could do this or not... ya'lls thoughts?
