Installed drop hats, now my suspension is bottoming out
  • JGood
    • Jan 2004
    • 7959
    I have very high mileage Bilstein Sports / H&R Sports. Probably 200k+
    They've worked great over the past 8 years or so. The other week, I installed e90 drop hats, and removed the spring pads (front and rear). Now I think the car is bottoming out on bumps/potholes, I get a very hard jolt and you can just hear it... it doesn't sound or feel good at all.
    So my question is, am I too low for the soft H&R sports? Or are my shocks worn and unable to provide enough dampening?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
  • xwill112x
    • Jan 2009
    • 4236
    h&r sports and billys is said to be one of the worst combo's because of the fact they're to low and to soft. i would start by removing the drop hats and see how it handles then.
    • JGood
      • Jan 2004
      • 7959
      Why would I do that? That's the way it's been for the past 8 years, I know it would be fine. The front pads were about 1mm thick, so that variable is negligible.
      • VacMan
        • Apr 2007
        • 2405
        WTF are you talking about? 50% of the lowered e30 world probably runs that combo with excellent results. I'm blown away by the amount of BS you spew.
        JGood, I ran into the same issue when I installed drop hats on my touring. I think taking away that last half inch of travel was enough to make it hit. I will say that after driving it for a few hundred miles the strut isn't as likely to bottom out, but I still cringe every time I drive over a big variation in the road.
        Bottom line: If it's been a short time since you took all the load off of the strut, wait a while for things to settle.
        • Vince30
          • 2318
          Send your stuff to me and I will see if I get the same results on my car.
          • stumble_t
            • Aug 2009
            • 759
            I have run this combo on 2 cars with no problem whatsoever(no drop hats though). Best street setup in the city IMO but to each his own...
            [IMG]http://www.r3vlimited.com/board/
            • Fidhle007
              I can fly, motherfucker
              • Oct 2005
              • 7209
              Please stop spreading your misinformed bullshit.
              '89 325is S50 Track Montser
              '04 X5 Daily/Tow Vehicle
              http://www.avarestoration.com
              http://www.myspace.com/brendanfiddle
              Click here if you want to be my zombie slave...
              http://www.youtube.com/user/Fidhle007
              • ak-
                • 12422
                Drop hats: ~15mm
                Pads: ~2mm
                Stock drop hat washer: ~1cm
                You've taken around .70 of an inch in shock travel to go lower which is a lot when you look at your shock think about it. I would say to cut a bump stop to gain another inch of travel, but H&R sports aren't the stiffest springs in the world either; so that would result in more risk of blowing a shock(though billies are super tough). As someone mentioned above, I really doubt it will 'settle' in and the dampening will go back to normal because I've been in your situation before and nothing really helped.
                My suggestion is to either toughen it out and drive carefully, go with a stiffer spring up front(race/IE3) to prevent bottoming out, or just go back to your original setup.
                If you decide to go with a stiffer rate up front, you can more safely remove a bumptstop to gain more travel.
                GL!
                1991 325iS turbo
                • Fidhle007
                  • Oct 2005
                  • 7209
                  Bilstein Sports have internal bump stops.
                  • JGood
                    • Jan 2004
                    • 7959
                    It's been about 3k hard miles.
                    Thanks for your input. It's nice to know someone else has the same issue - makes me think it's more a result of spring rate then it is of wear on the Bilsteins (Like I said, they have 200k+ miles). I didn't want to go out and spend $400 on new Bilsteins for no reason. Instead I'll probably spend $300 on H&R race springs. My track car has new H&R Races, I'll probably pull them off and throw them on this car just to get a feel for the ride height and quality before spending the money though.
                    Thanks guys!
                    • Jean
                      • 18228
                      Originally posted by ak-
                      Drop hats: ~15mm
                      Pads: ~2mm
                      GL!
                      +1. I've ran the billy sports/hr sports on my car as well, it they felt good when the road was nice. I do have to say though since they were fairly soft shock would run out of suspension travel easy when you hit a bump or dip on the road. Honestly I like the ride of the stiffer spring rates, at least this way you aren't riding on bump stops everytime you hit a bump ;)
                      • xwill112x
                        • Jan 2009
                        • 4236
                        I'm not spewing bullshit. Everyone that uses the sports complains about body roll, bottoming out, them being to low for they're softness.
                        They bottom out like cut stockies up front when hitting a raised portion on the pavement. But it's fine, dont believe me, i'm just someone who has actually had sports and speaks from experience.
                        • ak-
                          • 12422
                          Yes.
                          You hammer/chisel the bottom cap and the rod comes out showing 3 of them.
                          1991 325iS turbo
                          • ak-
                            • 12422
                            And oh look, I found your solution:
                            1991 325iS turbo
                            • JGood
                              • Jan 2004
                              • 7959
                              I have a Tirerack.com account, I can get them for $285 brand new
                              The money isn't the problem, I want to be sure the springs will fix the problem. I'll put my track cars H&R Race springs on this car and find out.
