The suspension setup/ride height thread
      ahhh thank you sir
        Round 2:
        Full GC kit with Konis and shortened strut housings.
        Are Three Vee
        Dad Spec
          H&R Race up front before I installed the rear. Just wanted to show it off for kicks. :P
            Eibach Pro-Kit
            Eibach Pro-Kit, -1.6" front, -1.4" rear. Boge Turbo Gas Strut inserts and rear shocks. The Eibachs are comfortable and the Boge's are a matched well to the spring rate.
            1989 325i
              reverse rake =/
                Bilstein Sports.
                H&R Sports.
                15mm Drophats.
                All pads in.
                COTM
                  Noob question
                  i have bilstein sports and ie3s at home. im gona install them on sunday
                  but people keep saying that i need to cut the shock or something??
                  does anyone have a write up w/pics or some sort of explanation?
                  thaank you
                    Originally posted by Anguz View Post
                    Noob question
                    thaank you
                    You dont need to cut anything. But unless you lop off a front dead coil or get drop hats your going to have reverse rake on your late model.
                      i got e90 drophats standing by
                        Good. You will likely need more though. But try it out first though before you permanently modify your springs.
                          well i dont want reverse rake
                          what if i leave 1 spring pad in the rears?
                            look at my posts at the top of the page
                            bilstein sports, IE3's, no pads up front, 1 pad in the rear (lower) and Drop Hats
                              reverse rake =/
                              It's an illusion. The plastic bumper cars have lower rear fender arches.
                              I've had lots of lowered cars in the past. There is such a thing as too low. Not just for comfort, handling will absolutely suffer. When ever I see a car with a slammed suspension, one word comes to mind - POSER. Honda, BMW, it doesn't matter.
                              1989 325i
                                Bilstein Sports w/ BavAuto Springs
                                Eibach Sways
                                All AKG poly bushings
                                Turner Swaybar reinforcements
                                Fr/Rr strut braces
