Cannot get my steering wheel straight!
  • Jand3rson
    • 37587
    I have an M-Tech II steering wheel, and since I bought it, I simply cannot get it to line up straight. Everytime I try to adjust it, it's still sitting crooked, either to the left or right. Has anyone else had this problem? How do you fix it? It's making me nuts!
  • Mot
    45 toting redneck
    • 4018
    i had the same problem josh. the trick is to find a nice empty road ( shouldnt be hard in bend) and drive slowly in a striaght line @ 5-10mph at the most. Loosen the nut and put the steeringwheel on straight. Then tighten it down, wala straight steering wheel.
    • Jand3rson
      • 37587
      I tried Mot's suggestion, went out for about 20 minutes up and down a straight road, and still cannot get it straight. It's like there's ONE spline in between just a bit too far right and just a bit to far left, and if I try to put it there, it just won't go on. This is making me NUTS.
      • kencopperwheat
        King of Kegstands
        • 14396
        Maybe it's your rack or allignment? Did the original wheel fit perfectly straight?
        Originally posted by Gruelius
        • Jand3rson
          • 37587
          As far as I knew, it was only in there for 4 days. :D
          I'm going to do an alignment when I do my suspension at the end of the month, maybe that will fix it. I seem to remember someone, I think it was Jordan, saying that could be the problem.
          • Jordan
            • 12913
            You need an alignment josh.
            https://mtechniqueabs.com/
            • Jand3rson
              • 37587
              See, I told you it was Jordan. :D
