Just got some new wheels and the front isn't quite low enough. Is it possible to get more of a drop out of the h&r spring / bilstein setup? This set is so common among our cars that I'm hoping someone has had the same problem and found a solution. (Besides buying coilovers obviously). Thanks.
Can you lower the H&R / Bilstein setup?
e90 spring hats are drop hats and are way cheaper than custom drop hats.
'89 Alpine S52 with goodiesComment
My H&R sports and Bilstein sports that I ran for 7-8 years without a problem, now bottom out badly with the e90 drop hats installed.
I'd look at other options if I were you.
I'm installing the H&R Race springs from my track car into my street car for a weekend to see how they feel. I think the higher spring rate and shorter height will give me the drop desired and spring rate needed to avoid bottoming out the Bilsteins.Comment
