This is kind of a silly question but I need to be 100% sure before I proceed here. I bought a used GC kit with no instructions hence why I am begging for help here.
In this pic are the taller springs the fronts?
If you look carefully you can see that the taller spring tapers a bit at either end where the shorter one does not.
Looking at the pictures of full kits on the GC site it appears that the taller springs with a bit of taper should be on the front but I am not totally sure since the rear springs are a higher rate and I would expect them to be beefier than the fronts then.
Can anyone shine a light on this for me?
