So my suspension is f'ed up
  • Brew
    • 3060
    Had my car up on a lift this afternoon swapping out the blizzaks for the es100s. When I lowered the car the left-front suspension would not compress at all. I have ground control coil-overs and when the car was on the ground, the spring on that corner was still completely loose.
    So, I guess my question is: Has anyone else run into this before? Anyone have any ideas on how to un-seize the strut? The thing does not budge at all, even when the corner is lowered onto a block of wood. I'm guessing that I'll just have to replace the struts. :(
    '91 318is
  • DanGillan
    • Mar 2004
    • 4061
    did you try standing on the bumper and pushing up and down? or driving at all?
    Dan
    • Jarvis
      • 2132
      Dan - he drives it everyday, usually pretty hard to. Whatever is wrong isn't going to fix itself by just driving more.
      • Brew
        • 3060
        Any tricks for removing the threaded collar that holds the shock into the strut tube?
        '91 318is
        • Jordan
          • 12916
          Use the BMW special tool.
          but no one has one.
          So use a pipe wrench.
          https://mtechniqueabs.com/
          • Brew
            • 3060
            but no one has one.
            Yeah, I got one of them off with channel locks, but the left side wont budge at all. I guess I'll just soak the fuck out of it with some penetrating oil tomorrow and bust out the 2 foot pipe wrench.
            '91 318is
            • Skafrog
              • 1732
              Ford K-Body strut removal tool. You have to enlarge the holes, but it will fit in the holes. Use a breaker bar on that. Go get it at autozone.
              NASA MidSouth TT Director / GTS2 #018
              Mods: Coastal PS Fluid, 10w40 Oil
              Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
              • Brew
                • 3060
                Thanks for the suggestions, I'm going to give the pipe wrench a shot tomorrow and if that doesn't work I'll go to more drastic measures. :evil:
                '91 318is
                • Brew
                  • 3060
                  Thanks for all the help guys, the pipe wrench did the trick.
                  '91 318is
