E36 rack
  • 85Dirty30
    • Sep 2009
    • 205
    E36 rack
    As some of you know i just got an 88 325is and it has a "e36 rack" i was wondering if there was a way to tell if it really is an e36 rack? the car car also needs inner and outer tie rod ends. If i was to get tie rod ends and it is an e36 rack what tie rod ends do i have to buy?? o and by the way this is funny :hitler:
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    Count the number of turns it takes the steering wheel to go from lock to lock. If it is less then 4 its probably a E36 rack.
    You can use E30 or E36 tie rods.
    • FredK
      • 14762
      Look at how it's mounted to the subframe. If there are spacers holding it to the ears of the subframe, then it's a non-E30 rack--most likely an E36 rack.
      • 85Dirty30
        • Sep 2009
        • 205
        its about 3 turns lock to lock
        • 325ix
          • Aug 2009
          • 7783
          ^should be an e36 rack then. A regular e30 is about four I believe.
          • kingston
            • Jun 2010
            • 2669
            I'm jealous. I want a Z3 1.9 rack!! Someday...
            Originally posted by LJ851
            kingston is the play by play announcer for this thread.
            ‘Tis by the grace of God that my cars run!
            Originally posted by unloadedak
            #teamross
            Siobhan's Build Thread - UPDATED!
            • Wh33lhop
              • 11705
              I would get E36 tie rods and USE E36 LOCKING PLATES. Do NOT use E30 locking plates with E36 tie rods, you may die and that would be bad.
              paint sucks
              • blunttech
                • 12850
                get either of the assemblies The e36 are a couple bucks cheaper in Lemforder but the lock plates are more . youll be in for less with lemforder e30 assemblies and e30 lock plates
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                • Boris1111
                  • 250
                  If it's about 3 then you have an early e36 rack or a rack from a S50 M3, which is 3 lock-to-lock, later e36 3-series had 3.25 and the Z3 has a 1.9 I think?
                  • dnova89
                    • Aug 2009
                    • 851
                    The non-M z3 rack is 2.7 l2l, the z3m rack is the same as any e36 rack which is 3.2 l2l, only the '95 m3 is 3 l2l
                    The non-M z3 rack is the best one to have, not because of the shortest l2l, but because it is has a linear ratio. (same rack travel per input turn across the entire rack length as opposed to the z3m and any e36 rack which is a progressive ratio.)
                    -Darius (aka DiscoDoughnuts on other forums)
                    dude man bro...
                    • Frog
                      • Jun 2010
                      • 980
                      LOL
                      Z3 is 1.9........ Liter! Imagine driving a 1.9 lock-to-lock.
                      Winner winner chicken dinner?
                      My Seller Feedback Thread
