IE3 + Bilstein sport = hitting my muffler
  • mamzak
    • 883
    Just did the typical IE3 and Bilstein sport suspension overhaul, but now my stock muffler (bosal from the M42) Is banging against the drivers side shock. Anyone else have this problem/a solution? I'm thinking just take mechanics wire and tie it over to the right a little? Any better ideas?
    All girls fuck but not all girls fuck around with combustion engines.
  • ak-
    • 12422
    Maybe I'm ignorant about it, but how would your muffler/exhaust start hitting your shock from just going lower? What else did you change?
    1991 325iS turbo
    • reelizmpro
      • 9559
      Perhaps they cut the pipes too short when they installed the muffler so it's too far forward and hitting the shock bolt? This was the case with my exhaust.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • caliGreen
        • 195
        you shure its on the right mounting brackets?.... modfied pipeing? pics?
        • mamzak
          • 883
          Yeah I just got a brand new stock exhaust from the cat back like a year ago, all the mounting points are correct. Looking birds-eye, with the top being the front of the car, it would look like the top left corner of the muffler body is beside the lower shock bolt, like probably within a micrometer, so that any vibration makes the muffler rattle like hell against the shock. but now if I pull the muffler over to the right I'll be hitting the hole in the valence for the exhaust. Fuck it, I'm going to go take pics. BRB
          • mamzak
            • 883
            You can see the yellow shock hitting the muffler there....
            • M-technik-3
              • 18946
              Check your rubber hangers they just might be getting weak and old.
              • ak-
                • 12422
                I have a very odd feeling your muffler was installed upside down.
                Think about it.
                1991 325iS turbo
                • mamzak
                  • 883
                  Think about it.
                  What makes you say this? How can you tell?
                  • ak-
                    • 12422
                    here is a stock 318 muffler.
                    see the angle of the tip and such? it is exactly like yours but "flipped over"
                    1991 325iS turbo
                    • mamzak
                      • 883
                      Are you sure? Hmmm. But that would mean the tip would be even more angled than it is now, because if it was flipped over the outlet would be more to the right. Fuckers....
                      Can someone else with stock 318is exhaust post a pic to compare?
                      Also: would this change where it's sitting in relation to the shock? It would be a symmetrical flip wouldn't it? It shouldn't matter if it's upside down or not?
                      • ak-
                        • 12422
                        If you flip it right now, it will be a little offset going towards your spare tire well with the tip angled properly.
                        I'm just speaking through opinion and what I can make of this, I don't have a 318.
                        1991 325iS turbo
                        • 325issguy
                          • Dec 2005
                          • 261
                          Looks like what someone said above... The muffler piping needs to be extended back an inch or two... Ill check tommorow on my 318 muffler and see where it sits with the same suspension.
                          • Teaguer
                            • Sep 2004
                            • 6167
                            WTF !! How can this be such a big problem that its thread worthy?
                            Also your muffler is NOt upside down so relax.
                            Why don't you loosen the rear hanger that bolts to the subframe and pull your exhaust over and tighten it back up?
                            This will do the trick.
                            Alternatively you could just try pulling the exhaust over without doing anything to the hanger as it seems your mechanical abilities (as well as other things) are limited.
