Shaking at 50 to 60.. Whats main culprit?
  • nicky51
    • Jan 2010
    • 158
    OK. Ive had enough of this shaking at 50 to 60 mph.. Im thinking control arms but theres many suspension parts.. what would be the main culprit and which pieces should i change first... Thanks...
  • Aptyp
    • 6584
    for me, it was tires.
    • Sagaris
      • Sep 2009
      • 2243
      for me it was lower control arm bushings
      • siazul
        • Jul 2010
        • 185
        sounds familiar, my steering wheel shakes at about the same speed, only now that I installed new tires
        • M-technik-3
          • 18946
          Suggest you do an inspection as it's the only way to determine what's bad.
          • jasonsnoddy
            • 1900
            +1 my front tires weree so old one of them had separated from itself and was all uneven.
            Originally posted by stewie30luvr
            ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
            Originally posted by JakeP
            with a coathanger
            • nicky51
              • Jan 2010
              • 158
              Reply
              O.k. I already changed the sway bar end links but i think the control arrms will be next.. besides that what other front suspension pcs would i need to look for? and do the control arms come with the bushings? thanks...
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                A speed specific issues usually points to tires, as listed above. Try a tire rotation first. Then take them in for a balance. Also check the hub surfaces, and answer me one question, do you have aftermarket wheels?
                • McGyver
                  • 4637
                  i would suspect the balance of your tires as farbin said. if they shake at another speed range you know you're out of balance for sure.
