tight steering
  • dreamchasin
    • 3892
    tight steering
    So I put an m50 into a shell i bought and when I steer it has tight spots. If i turn left it's at about 10 o'clock (worst tight spot, lasts until 8 o'clock) and then there are tiny tight spots if i'm turning right at about 3 o'clock. it's always in the same place. I looked at the rack and there seems to be no issues with it, it was replaced. says remanufactured and ZF on it. I replaced the front subframe and didn't notice any issues with the steering rack either. It's full on fluid (was told to use power steering fluid and not ATF) and tires are at the correct pressure (42 PSI - tires say 44 MAX) I don't think the fluid is the issue to be honest. I checked the joints from the column to the rack and they seem to be fine, nothing is getting caught up anywhere from what I can see. Help will be greatly appreciated.
    EDIT: the car DID sit for a very long time. Just thinking of it now should i spray some PB blaster on the steering joints and drive it around/move it around?
    90 325is alpine2 m50b25 becoming a dorifto car.
  • franko2490
    • 501
    I've got the same problem with my vert... subscribed ! :( . My car also sits a lot in the garage, so that might be an issue . And also, mine does that only in cold weather ...
    Originally posted by E30_fiend
    Simply sexy.
    Originally posted by PУCCKAЯ_e30ka
    man... I took my little E30 outside for a ride, now 5sp.... there is no other car like E30... PERIOD. Don't know how to explain, but driving E30 is like having sex with a girl of your dreams, but the girl is a bit inexperienced, so you have to show her what to do and she will do it beautifully! ohhh man... after I got the 5sp tranny in it, it is all new love all over again! :)))
    • dreamchasin
      • 3892
      I'm gonna go spray PB blaster on it. I will be back in about 5-10 min to let you know how it went.
      • franko2490
        • 501
        Thanks, I am waiting :D
        Simply sexy.
        • dreamchasin
          • 3892
          Sorry, it didn't do anything. I can't figure it out.
          • franko2490
            • 501
            this is driving me crazy ... bump ... help please !
            Simply sexy.
