Strut insert removal problem
  • jimi318is
    • May 2004
    • 152
    I have my struts out and disassembled except for the insert, I can't seem to get the stock insert "nut" loose. Any tricks to this?
  • Teaguer
    • Sep 2004
    • 6167
    Big fucking pipe wrench .
    Nothing fancy about it , just man up . :D
    • BahnE30
      • 1050
      put a pipe on the end of it, if your that much of a woman.
      • Nitrox
        • Mar 2004
        • 43
        I had the same prob with mine. One was seized. The crappy pipe wrench that I had wasn't working either - just turned on the nut and ground it to hamburger.
        What worked was clamping the assembly down, heating it up with a torch, tapping around the nut with a hammer, and then using a hammer and a chisel at an angle to undo it.
        HTH
        • Digitalwave
          is a poseur
          • 6299
          Get some PB Blaster, a propane torch, a chisel, a large hammer, and a pipe wrench. With these tools you will be able to remove it.
          RISING EDGE
          • Teaguer
            • Sep 2004
            • 6167
            Or you could just ask your big brother to do it for you . :P
            • BahnE30
              • 1050
              OH SNAP.
              • jimi318is
                • May 2004
                • 152
                Yea, thanks guys, got them off yesterday morning. Had to borrow a large vice to hold the strut down while I loosened it, that was my problem, I had nothing to hold the strut. With the vice they came off fairly easy. I'll get some pics of it now that it's dropped along with t-stars :twisted:
                I totally gutted and transformed the suspension with new control arms, urethane offset bushings, struts/shocks, GC coilovers, GC camber/caster plates .....and of course, the T-stars.
