Who's using Koni top adjustable rear shocks?
  • robrez
    • Jul 2008
    • 3376
    I'm sure there are a lot of people using the GC or TCK top adjustable rears and liking them. But who's using the off-the-shelf Koni 8041-1186 sports?
    Any reason to think they would be too soft for H&R sport springs? I think they'd be fine, but since they are made for solid axle Mustangs, I'm not positive.
    January 2012 COTM
  • Gooch
    • Dec 2006
    • 1674
    TCK does not re-valve their shocks for the e30 kits. I don't know off hand what my part numbers are for the rear shocks from the D/A kit, but I'm sure TCK will be more than happy to give that information. They told me the part number for the fronts because I had to purchase a new strut insert.
    EDIT: Never answered the question. I'm not sure how they'd perform with H&R sports, I don't know if that is enough spring. I run a 700# spring in the rear with the D/A shock.
    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
    '87 535i - Vacuum brake conversion [SOLD]
    '93 525iT - 5-speed swap - 320k and counting
    '09 328xi - 6-speed
    • robrez
      • Jul 2008
      • 3376
      Thanks for the info., it look like TCK sells top adjustable SA rear under part no. 8041-1186TCK and labels them a "TCK exclusive". So I wonder if they revalve them or shorten the bodies or just modify them to fit 10mm rsms. I should call them and ask for their corporate secrets, but that seems kinda douchy.
      In any case, it would appear that the top adjustable koni mustang shocks are OK for a lowered e30 suspension?
      And are you using the 12mm rsm's?
      January 2012 COTM
      • Gooch
        • Dec 2006
        • 1674
        Correct. I'm running the TCK monoball rear shock mounts, according to their website it seems like they are 10mm.
        '09 328xi - 6-speed
        • DRTSRFR
          • May 2008
          • 1836
          All top adjust rears are 12mm.
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • M-technik-3
            • 18946
            Mustang uses the 12mm ones.
            • DRTSRFR
              • May 2008
              • 1836
              They have to be 12mm. You can't get the adjuster rod in a 10mm shaft.
              • StereoInstaller1
                GAS
                • 22679
                So how does this work, do you punch a hole in the trunk liner, or are these more of a "race only" app so no one runs a trunk liner?
                Closing SOON!
                Thanks for 10 years of fun!
                  • 34836
                  unless you are adjusting these things at every track day/between autox runs, you don't need top adjusters.
                  Basically set it and forget it. I've adjusted my rear shocks maybe 3 times in the last 8 years.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    Gooch........e mail sent.
                    • StereoInstaller1
                      GAS
                      • 22679
                      Makes sense. I figure I am gonna have the heaviest E30 on the planet, but I want it to retain some decent handling.
                      Closing SOON!
