Uneven ride height
  • lolcantturn
    • 4588
    Uneven ride height
    My car sits on somewhat of a slant
    now, I didn't install the Eibach springs that it has now. The previous owner did.
    My ride height is uneven. While it doesn't bother me driving, it does bother me looking at it. What could be it?
    BTW I was looking at my rear axle assembly, and I saw that the sway bar stabilizer link bushing is all sorts of fucked up. I know it has no correlation to the ride height, but what would changing it do?
    Originally posted by TSI
    OEM+
  • bmwstephen
    • 2463
    could be the way the spring is seated on the spring perch.
    • lolcantturn
      • 4588
      would I have to rip out the entire strut to redo that?
      OEM+
      • bmwstephen
        • 2463
        well yeah... but you can try giving it a visual look. Have the steering wheel and wheels straighten out and in the strut assembly and spring should be nearly identical looking
        • lolcantturn
          • 4588
          yikes, I'll do a full inspection tomorrow.
          OEM+
          • Philo
            Ich esse kleine Kinder
            • 3334
            You can jack the car up in the air, reach your arm to the spring, and make sure the end of the spring is in the correct place on both the top mount and the seat.
            -tim
            Originally posted by Jordan
            I like the stance
            • iignite
              • 125
              I honestly think its a Eibach thing. I have them too and my rear right side is sagging as well.
              • lolcantturn
                • 4588
                I hope not.
                I tried to move the spring with my hand..nothing went into place, it actually seemed seated well
                OEM+
                • J0nnyr0ck3t
                  • Jul 2010
                  • 80
                  It shouldn't be that difficult of a fix. Just take a weekend off and really examine the car by jacking it up and making sure everything is where it needs to be. Who knows it may just be the actual strut completely gone. Does your car bounce everywhere you go? Try taking some pictures of it on its side from afar.
                  I guess its time for some C/o's. But i
                  Practice the study of E30ology.
                  • YeOldeBuggy
                    • 208
                    If it was ever wrecked, the body could be twisted a bit, I've seen it on a 1989 mustang gt that I owned. It sat about an inch and a half lower in the driver side front and passenger side rear.
                    Thad.
                    Need BMW parts?
                    http://www.blunttech.com
                    or face ultimate peril.
                    • lolcantturn
                      • 4588
                      Thanks, I'm sure it can't be too difficult but I just got to find what's wrong. I'll jack it up and have a thorough check.
                      Car isn't bouncy at all.
                      Thad.
                      Gee I'm not sure if it was wrecked, the body panels line up pretty well it looks like. I hope it isn't because the body is twisted, because this uneven ride height is going to bother me shitless.
                      OEM+
                      • lolcantturn
                        • 4588
                        Ok so upon inspection, the only thing I could see is that the stabilizer bushing for the front left looks more worn than the other one...so maybe that's why its sagging a little more......Could that be? :/
                        OEM+
                        • lolcantturn
                          • 4588
                          Bamp
                          OEM+
                          • lolcantturn
                            • 4588
                            What good will changing sway bar links do?
                            The bushing on my rear right and front left look pretty worn. Those are the only suspension parts I see that look noticeably worn.
                            OEM+
                            • Philo
                              • 3334
                              Those aren't going to account for the uneven height.
                              I'm betting that something is bent due to a previous accident. Have you verified that the dampers are still in good working order?
                              -tim
                              I like the stance
