Uneven ride height
  • lolcantturn
    • 4588
    Originally posted by Philo
    Those aren't going to account for the uneven height.
    I'm betting that something is bent due to a previous accident. Have you verified that the dampers are still in good working order?
    To be honest, they look like the original dampers. My car has 270,000 miles.
    I lifted the car, from the center of the rotor to the fender, one side is .5cm longer than the other. That kinda isn't translating to how uneven the ride height looks in the photo though.
    Originally posted by TSI
    OEM+
    • StereoInstaller1
      GAS
      • 22679
      Replace your trailing arm bushings
      Closing SOON!
      Thanks for 10 years of fun!
      • Philo
        Ich esse kleine Kinder
        • 3334
        Come on Luke. Don't turn the tech forum into a place where we just tell people to replace random items, especially without providing reason.
        From the sound of it, the OP doesn't seem to have a full understanding of suspension components. I'd take the car to a local BMW shop, and have them look the car over. Most places will do it for around $50.
        -tim
        Originally posted by Jordan
        I like the stance
        • DÃŒEGØ
          • 690
          so is it the front or the rear [left] that sags? or the whole left side?
          I also think it might be a blown shock.......
          Driving:1990 325iS, 2007 335i :devil:
          past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
          • StereoInstaller1
            GAS
            • 22679
            OK, so here is the deal: the rubber of the TABs wears out long before we get these cars...and then we lower them.
            When you first drop the car, the bushings are now "resting" on "newer" rubber and have some added strength due to that newer "contact patch". After you mob around for a few weeks/months/years, that old ass rubber deforms again, only it is WAY worse than before as now you have the new area all mushed out PLUS the area that was worn out before you lowered the car...making sense now?
            This issue is also made worse by geometry. I am sure one of you fucking whiz-bang college guys could spend all of .2mS to figure out the actual numbers but the reality is that 1mm of deflection in the bushing is gonna be about 20mm of movement at the axle. Duh, right? With all the obvious geometry changes it only makes sense.
            So...the other thing is how much a decent set of urethane TABs change your E30. The ass end becomes about 100X more stable, especially in the wet.
            The other advantage is a HUGE improvement in tire wear...but that is another topic, isn't it?
            So, all of the above is reflected by what happened in my own car: when I changed the TABs, my car went from a clear right tilt down (measured about 1.25" different IIRC) back to 100% normal.
            So, there ya go, a goddamn explanation. Your 22 year old rubber is shot, whooda thunk?
            Closing SOON!
            • lolcantturn
              • 4588
              Fair enough. I can do TAB's by myself right? How long should it take?
              OEM+
              • Philo
                • 3334
                Thanks for the explanation Luke. Now many can come back to this thread and read the explanation for your diagnosis. I just hate it when a board just tells people to replace items without reasoning, and is the main reason I can never find solid info on E36 sites.
                -tim
                I like the stance
                • CabbE30
                  • Aug 2009
                  • 2358
                  Im assuming I should replace my TABs when I change my springs n struts then?
                  • accident
                    • 7303
                    if you dont know when it was done last you should do it anyway.
                    Moral of this story?
                    • Danny
                      • 14216
                      Soft, cheap springs + years of having a driver sit on one side = sag.
                      • StereoInstaller1
                        GAS
                        • 22679
                        Let me make this perfectly clear: changing TABs is a FUCKING BITCH to do. Took me 3 hours on a lift with every tool you could dream of.
                        Closing SOON!
                        • lolcantturn
                          • 4588
                          ..........................I guess i'll have to ignore my uneven ride height then..
                          OEM+
                          • StereoInstaller1
                            GAS
                            • 22679
                            Find some poor fool to do it for $150. As tough as times are, you will be able to.
                            Closing SOON!
                            • accident
                              • 7303
                              if you were in california i would totally do it for $150 lol
                              • lolcantturn
                                • 4588
                                F that! Is the majority of the work just taking the bushing out?
                                I'm getting Bilstein HDs because my car is way overdue for shocks...that may or may not fix my uneven ride height, but it will fix my spine when I go over the smallest of cracks :)
                                OEM+
