Drop hats rubbing
  • bmwstephen
    • 2463
    are you also using the thicker washers provided by the drop hats?
    • Sagaris
      • Sep 2009
      • 2243
      Yes, the thicker washers are being used.
      • bmwstephen
        • 2463
        one last question sagaris, when you put the mounts on the drop hats, do they sit an angle like the stock e30 hats or do they stick straight up
        • Sagaris
          • Sep 2009
          • 2243
          I don't think that they sit on an angle. The spring hats are flat and the strut mount is flat so I am thinking they fit together flat. I did not notice anything weird like that.
          • Ryan...
            • 2448
            sssooooo, should I pre-emptively grind mine down? I just got mine in the mail from Blunt a couple days ago and haven't installed them yet.
            2007 Range Rover Sport S/C
              • 37833
              Guys, E90 drop hats are FINE. It's the aftermarket hats you should worry about.
              Grover Beach, California
              BimmerHeads.com
              • bmwstephen
                • 2463
                well.. its mixed. I haven't experienced any issues with those drop hats version I have a quarter inch of clearance with my new boge mounts but supposedly they were redesigned during the last years of the e30. in any event its best you probably take side pics of your stock mounts with the drop hats for us to compare
                • Ryan...
                  • 2448
                  Ok I can do that in a couple days when i can get my car out of the driveway :)
                  • Sagaris
                    • Sep 2009
                    • 2243
                    If the hats are somewhat oblong/oval/cam shaped and not a perfect circle, then I would grind down the oblong part as well as grinding the sharp edges that can potentially dig into the undercoating or metal. Make the edges dull, paint over it and you are set. It sucks to install all new suspension,then take it apart again because of something like this
                    • Ryan...
                      • 2448
                      Ok I'll definitely check that then. I got just about every suspension part sitting in my basement waiting to be installed right now, I'd hate to have to take stuff apart again a week from now and have to fix it then!
                      • AirplaneBuilder
                        • 823
                        I had the 15mm drop hats installed with the thicker washers and had no problems! i used them with h&r sports, bilstein sports and i like to take corners pretty hard to see what the car can handle and not once had an issue. i just replaced my suspension with coilovers and took the hats off and they had no signs of scratching or wearon them. I guess it depends on what you get from kieth richards weather good hats or oblong ones....
                        1989 Zinno 325i S50 ZF320
