Suspension tire q???
  • m30power
    • Jul 2008
    • 74
    Car:
    1990 325i
    suspension: Bilstien sport/h&R race. Car does have front and rear sways.
    Wheels: millie miglia 16's and im running adapters so they fit.
    My car eats through tires like no other. I go through a set every 8 months (8-10xxx miles). I do not track the car, or go crazy with it. Its a DD and I bought it with the suspension already done. I love the way it looks and would like to keep the same look.
    Ive tried getting alignments done but shops say its b/c of my suspension. There is definite scalloping in the wear pattern, and the tires only wear on the inside edge. Is there any way to correct this so I dont eat tires like crazy...or is a different suspension the only way to go?
    thanks guys!
  • shiboujin
    • Feb 2006
    • 2791
    Raise the car or get camber plates for the front and weld in tabs in the rear.
    You will lose the JDM hella tyte neg camber look. But that's the point.
    • priapism
      • 1182
      Neg camber causes wear on the inside of the tires. You get that from running springs so low. If you don't track the car why go with H&R Race? Get something taller that won't cause such neg camber.
      -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
      • Wh33lhop
        • 11705
        Yep. You will have to dial out camber and rear toe, which you can do either by raising the car up, or getting adjustable gear (rear subframe spacers or weld-in adjustments, camber plates up front).
        paint sucks
        • RickSloan
          • 2401
          because he likes the way the car looks how low it is.
          You need camber plates like said above. We have them at the shop for a good price or you can order online thru a couple different companies. If you buy them i can help you put in the fronts, but i have never welded in the rear stuff
          Need Illustration or Design work? www.robbiebyerly.com
          • m30power
            • Jul 2008
            • 74
            I didnt decide on the H&Rrace. They came on the car when I bought it 2 years ago. Tires are just getting expensive!
            I do love the look of the car, but tire cost is killing me. Robbie what do camber plates typically run??
            and thanks for the offer bud youve helped me out more than once!
            • shiboujin
              • Feb 2006
              • 2791
              camber plates are like 200.
              you can just get extra spring pads in the rear and maybe space the front if you're super cheap.
              • m30power
                • Jul 2008
                • 74
                Yea I do have spacers on all 4 so the wheels fit
                • StereoInstaller1
                  GAS
                  • 22679
                  Part of the issue is squishy ass old bushings.
                  How do I know? I had the same issue.
                  I put Urethane bushings in the rear and am now getting 2X the tire life.
                  I will be doing the adjustable camber/toe kit in the rear and camber plates up front...but my goal is damn near stock alignment spec.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • m30power
                    • Jul 2008
                    • 74
                    do you mind letting me know what bushings you had installed??
                    • LJ851
                      • 7919
                      camber does not cause high tire wear . toe is the culprit. either way you need to jack it back up to get rid of toe (which will remove camber too), or weld in toe adjusters only and dial out the toe but retain the camber . if you want to get rid of camber , weld those in too and adjust.
                      Lorin
                      The M30 is God's engine.
                        Old and worn out rear trailing arm bushings will increase rear tire wear, but the main problem in this case is the camber gain from the lowered ride height of the H&R Race springs. New RTAB's (be they urethane or OE) will help, but the only real fix if the springs are to be retained is camber plates up front and eccentric RTAB's or weld-in cambe/toe adjusters in the rear.
                        Scalloping of the tires is most commonly caused by worn out shocks. When used with H&R race springs I'd guess on a life of no more that 40k for a set of Bilstein Sport shocks.
                        • StereoInstaller1
                          GAS
                          • 22679
                          All the camber fix in the world means nothing if the trailing arm is flapping around under torque or lateral load.
                          TABs make more difference than you would ever think!
                          Closing SOON!
                          • nrubenstein
                            • 3148
                            New stock, not urethane. I made the the mistake of installing polyurethane bushings, and all it got me was a chance to drop the rear subframe out of the car a second time. New stock feels great, is dead quiet and will never squeak.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
