Questions about Konis
This topic is closed.
  • Jand3rson
    • 37587
    I've got my new Konis finally, ready to go in soon, but I have a few questions, as I'm a TOTAL suspension noob, so here goes.
    1. I know that with the rears, you twist the shock itself to adjust the stiffness, and the front uses the knob at the top. But how far do you turn the shock each way to get to each setting? It seems like they just turn forever.
    2. Is there anything in particular that needs to be done when I put them in? In other words, can I just remove my old shocks and install these, with no problems?
    3. Is there a break-in period for Konis? In other words, do I need to drive with them at a certain setting for a certain period of time?
    • 34847
    josh, to adjust the rear ones you have to remove the bump stops and compress them all the way first. also, you need to run them at full soft for a little while to break them in.
