Switching to non airbag steering wheel?
  • 801coppertop
    • 293
    I would like to put on a new steering wheel on my car, mtech 2 maybe? However its a 91 has an airbag, the wheel i want does not. Will this cause problems? Is there anything i need besides a new wheel?
  • mr.vang
    • 4371
    no..the srs light will be on though. also check with your state to see if its legal.
    • LagunengrunE36
      • 77
      Yeah, you'll need a spacer (#4 -- http://www.realoem.com/bmw/showparts...47&hg=32&fg=30).
        In addition to state laws that may prohibit disabling the SRS, your insurance could refuse to pay if you delete the air bag.
        • 801coppertop
          • 293
          Called insurance, they said all is well they wont refuse my benefits if a non-airbag wheel is put on. Also state law did say that you cannot remove an airbag unless you have a "special" license to do so. However i do not see how local authorities would be able to tell, unless an enthusiast...
            • 34847
            just do it, nobody is going to know or care. who knows if a 20 year old airbag even works, mine didn't do shit.
            • EN318isPDX
              • Oct 2007
              • 4373
              My car got T boned and the air bag didnt deploy, i often wondered if it was a ticking time bomb so i unplugged the computer, than removed the airbag, no SRS light and no BOOM! Until i hooked up a battery to the airbag and watched it blow up, wonder if i still have the video
              • 801coppertop
                • 293
                You mean like this,
                I used to help tech's blow up airbags at the land rover dealership in centerville when i worked there, it was a riot. They can send tires 20 feet in the air.
                • gearheadE30
                  • Jun 2007
                  • 3734
                  That wouldn't be caused by airbag failure. In an e30, the only situation that will cause airbag deployment is a frontal crash, i.e. hitting something head on, or in some cases, getting rear ended.
                  Project M42 Turbo
                  • EN318isPDX
                    • Oct 2007
                    • 4373
                    It was hit in the front, drivers side fender at ~40mph, it mashed the fender but didnt hurt anything else. it was pretty close to the crash sensor but im guessing you really have to smash it in order for it to deploy!
                    • bwawuz02
                      • Apr 2004
                      • 653
                      you need to get accessory stalks from a non-airbag car as well. I put an Mtech 2 wheel in my 318is, so speaking from experience here. Just go to a pick n' pull or post a WTB ad here. Just know that you need the key in the ignition to get the steering wheel off a junk yard car and the steering wheel has to come off to get the accessory stalks off. Also, if you do go the junk yard route, just snag the spacer ring from the car there.
                      • acolella76
                        • 2950
                        you can pull out the key cylinder by sticking a wood screw in the slot where the key goes and yanking that sucker out of there... no real need for the key but it does make things easier.
                        Here's a DIY
                        -Alex
                        • 801coppertop
                          • 293
                          Couldn't getting a new accessory stalk be avoided by putting the spacer on after the wheel before the locknut, hence sitting the wheel back further? Or would that not be a good idea i was thinking []wheel[] /nut? And Alex thanks for the link, lots of good info there.
                            • 34847
                            You don't *need* the stalks. It can be nice to have, but they won't fit perfectly either. - they will be bent too far backwards.
                            if you don't space behind it your stalks will be very close to the steering wheel - uncomfortably close. so ideally you'd swap stalks as well. I have a spacer in the back and in the front, sort of a compromise, but it works well enough.
                            and if you space it too far, your steering lock won't work.
                              • 34847
                              I did, and nothing happened.
                              I'm actually glad it didn't - seat belts work fine, the whole idea originally behind SRS is for stupid people that don't wear seatbelts. Now it's different but they put fucking airbags everywhere..
