Billy Sports with GC springs?
  • T La
    • Dec 2009
    • 190
    Anyone running billy sports with GC springs? I'm considering this because I want the adjustability of coils, and if i could get 450f 650r it would be only a little stiffer than an IE3 Billy combo. I wouldn't be re welding, just cutting OE perch and slipping on the GC coil.
    I understand that the valving would be off, but if anyone is doing something similar I'd like to know how bad it is. I don't track the car but I do want it to handle pretty well on the back roads.
    thoughts?
  • MG325i
    • Jan 2007
    • 805
    ill be running this setup fairly soon. your talking about the GC coilover kit with billy sports right? if so ill have mine installed in the next week or two.
    E30 325I > SOLD
    E30 318IS > SOLD
    E39 530I > SOLD
    EP3 > SOLD
    95 M3 > SOLD
    97 M3 > DD
    • T La
      • Dec 2009
      • 190
      yeah that's what I was thinking, just the 400 dollar spring coil kit, but do you need to run camber plates to fit those also?
      • reelizmpro
        • 9558
        Should be fine as long as you don't go too low on them.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • T La
          • Dec 2009
          • 190
          i want to go decently low, but will i need camber plates?
          • Hellabad
            • 807
            It will help add suspension travel to the front of the car, if you can add camber plates. If you buy them at the same time you would actually save some money too.
            I have several pictures of Bilsteins and how they relate to the strut, and pictures of how the camber/caster plates add travel in my gallery that is in my sig.
            Pm or call me if you have more questions,
            Jay
            Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
            Ground Control Gallery
            The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
            • ZenkiOwns
              • Jul 2009
              • 496
              I'm was planning to order the same exact set up today, but I didn't realize there were more than one type of camber plates. Whats the difference?
              And I didn't see any savings wen getting everything together, were you referring to shipping rates?
              • MG325i
                • Jan 2007
                • 805
                you dont Have to buy camber plates. other than adjusting the camber, it'll drop your car a little lower too.
                E30 325I > SOLD
                E30 318IS > SOLD
                E39 530I > SOLD
                EP3 > SOLD
                95 M3 > SOLD
                97 M3 > DD
                • richardb
                  • 2121
                  Can someone please measure their bilsteins length from top of the stud to center of bottom eyelet hole. Rear shocks. Thanks
                  Edit: both fully extended and fully compressed
                  Transaction Feedback!
                  • csermonet47
                    • Jul 2009
                    • 937
                    My signature picture has the same setup with the race camber plates. That was about as low as I could go with that setup. The touring camber plates will be fine for most people. Just call up Jay and I'm sure he will help you out. He is the man at this stuff.
                    Are Three Vee
                    Dad Spec
                    • KenC
                      King of Kegstands
                      • 14396
                      If you want to go really low, cut out half of the internal bumpstop of the Bilstein strut.
                      Originally posted by Gruelius
                      • T La
                        • Dec 2009
                        • 190
                        Do the race plates allow for more travel? What rates are you running?
                        I've heard about this from a few people, is there a write up anywhere or is it the type of think where once you get the part out it makes sense?
                        thanks guys
                        • nrubenstein
                          • 3148
                          thanks guys
                          It just makes sense when you have it apart. All you need to do is compress the strut until the bottom pops out (it doesn't require much force).
                          I will say that I'm ambivalent about the Bilsteins in this setup. It's alright, but you can easily tell that the dampers were not really meant for serious springs. I'll be swapping over to a GC Koni setup in the near future.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • KenC
                            King of Kegstands
                            • 14396
                            450/650 is going to be a lot stiffer than the IE springs. The GC ones are linear rates too. I'd dread springs that stiff in a DD.
                            • T La
                              • Dec 2009
                              • 190
                              on IE3s the progressive coils end up being fully compressed once the car is off of jack stands anyways, I have two friends with e36s running 600f 700r daily and the ride is fine in their cars... I could maybe do 400f 600r but i've heard that even with 700r on e30s the ride is fine
