camber correcting strut mounts
  • zandi
    • Apr 2004
    • 602
    where to get and whats good?
  • DanGillan
    • Mar 2004
    • 4061
    dealer, bmp, ireland, turner
    add or subtract .5 degrees of camber
    Dan
    • zandi
      • Apr 2004
      • 602
      which do I need to do, add or remove?
      I put in some H&R's and bilsteins and the alignment guy says he can't align my car to 100%
      • Bryson
        • 1490
        ask your alignment guy, dude. we can't read his mind...
        • zandi
          • Apr 2004
          • 602
          well doesnt putting in H&Rs usually give a specific amount of camber? how much camber should i have?
          • rs4pro3
            • 5808
            camber is personal Preference, there is a set amount the car came with from the factory and that's what the alingment guy can't get it to, when ever you lower an e30 you end up with more -camber which is good for handeling(to a certain extent), but not good for the inner edges of your tires. If you don't mind rotating your tires often, and buying new tires more frequent leave it, but if you daily drive it and only lowered for looks try to dial in more + camber to get back towards factory. You'll need to get the spec sheet from the alignment shop to what you car is at, to decide how much you need and then we can recomend adjustable mounts that may work. Like in my car one corner was -3 and the other -3.4 so I purchased a .5 degree crash mount from BMW to get both corners close to the same.(Car was hit hard in the one corner)
            85 325e 2.7 ITB'd stroker
            • gstuning
              • 833
              part #?
              cause I´m running redicioulus camber now,
              Gunni
              @ Prodrive / Aston Martin Racing
              • Brian 89 325i
                • 1450
                PN for the Correction mounts are 31-331-139-484
                I have them, they are pretty cool
                Brian
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Camber is a good thing. If you wear the inside egdes early, you're not driving hard enough.
                  Now toe, toe is what will chew through tires, and is the only thing adjustable on an E30. As long as that is in spec, leave the camber alone (as long as they are equal).
                    • 34844
                    how do you end up with excessive camber with H&R sports? I have hardly any front camber, I wish I had more!
                    • zandi
                      • Apr 2004
                      • 602
                      so is it better not to waste money on camber correction struts and just leave camber as it is? i need to replace my struts anyways so im wondering if i should do camber correction
                      • cthulu703
                        • Oct 2004
                        • 288
                        The IE street camber plates are a better choice than the offset mounts as they allow a range of camber adjustment up to -/+1.5, so you can dial in exactly what you want
