ground control coilovers
  • jeswaw
    • May 2008
    • 337
    Originally posted by phreshkid
    That's the spring rate I run but I don't have an IX, I just have a swapped 318is.
    How much flex do you have with you 650 rears? Are you still on a ballon style set-up?
    • Jb325is
      • 2137
      I run 550/750. It's tolerable on the street and awesome for autocross
      - '88 m54 coupe
      <3
      • reelizmpro
        • 9558
        What shocks? Nice E34 by the way. Rarely see nice/fixed up ones anymore.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • phreshkid
          • 4655
          I have yet to drive the car my friend. It has been sitting for months. Motor swap runs perfectly and is all ready for a full repaint which is expensive as all hell. I'll let you know next week some time.
          As far as balloon style setup, I'm not sure what you are referring to but I'm going to go ahead and answer no.
          • Jb325is
            • 2137
            GC "short" koni's and Koni SA rears. Thanks!
            - '88 m54 coupe
            <3
            • C_gannon09
              • Feb 2011
              • 5
              ok found a H&R kit for 850 instead of the 1700 for ground-control. i got the money I can spend for gc but are they really worth spending double the money? as far as i can tell gc are adjustable and the H&R kit is not.
              • nrubenstein
                • 3148
                If you want to go cheap, do the SE30 setup.
                2002 BMW M3 Alpinweiß/Black
                1999 323i GTS2 Alpinweiß
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 Alpinweiß/Black
                • Hellabad
                  • 807
                  I do not know what HR kit is for $850, but the GC kits come with camber/caster plates, rear shock mounts, bumpstops and all the little pieces that make it work together.
                  Additionally, there are two GC-e30 kits for $1499, that also have all those parts, assembled.
                  A "spec e30 kit" uses standard length front struts that will always be on the bumpstops, which is not good, as everybody is finally figuring out. This is fine, perhaps even desirable for a spec-e30 race car, but a bad place to cut corners for a street car.
                  If you are talking about just springs, The HR spec e30 kit is $349 most places, and the GC coilover conversion kit is $50 more but then, for $50, you get to:
                  Choose the ride height you want, instead of what you get.
                  Change the ride height.
                  Choose different spring rates.
                  Buy new springs for only $59 each if you change your car.
                  Discuss different springs with anybody on any forum anywhere.
                  Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                  Ground Control Gallery
                  The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
