Are these all supposed to be filled with fuzes?
nope, you have many slots for items you dont have, so no wiring harness past the box. Things like power sunroof, heated seats etc.sigpic -
you will need the wiring harness, and sometimes you need it all the way to the fuse box on some cars. Depends on if you have female contacts on both side of that particular fuse location in the panel.sigpicComment
the heated seat fuse location would be the bottom right one in the pic, look inside and if you have metal terminals in each end... your a lucky bastard and heated seats would be plug and play with the heated seat harness... if not, like me when i did my heated seat retrofit, to do it properly you have to open up the fuse box, run a wire into that terminal, and then out to its little plug under the dash...Comment
Why is this in the suspension section?'89 325is S50 Track Montser
'04 X5 Daily/Tow Vehicle
http://www.avarestoration.com
http://www.myspace.com/brendanfiddle
Click here if you want to be my zombie slave...
http://www.youtube.com/user/Fidhle007
