Rear Rim hitting fender
  • GThomas
    • Dec 2010
    • 869
    Hey wondering if you guys ever had issues similar to this. Recently put on my 16x9s and i noticed after a few test drives that it seems the rears are rubbing the outer lip of the rim on the inside of the fender (which are rolled). It looks as if its rubbing some of the clear coat/polish off the rim which is not good. I've got 450s in the rear which i think may be the issue. Thinking of going to 750 rears but after talking with GC it looks like i'll have to change out the hardware because of the smaller spring diameter. Any suggestions of rates, or anyone relate to this issue? Thanks.
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
  • Pussy30
    • Feb 2011
    • 463
    450s geez. Yeah get something stiffer and possible roll your fenders more. Are you running stretched tires? Usually the tire would rub first.
    • GThomas
      • Dec 2010
      • 869
      Yeah tires rub a bit but only on larger bumps, i think its just all the movement from the 450s.
      1991 318is S52
      1987 325i Vert
      1991 325i
      2011 e70 X5
      • E30SPDFRK
        • 5713
        Happened to my RF's all the time, I was only on 475's. Either get a better roll or get spacers and make only the tire rub ;)
        Byron
        Leichtbau
        • GThomas
          • Dec 2010
          • 869
          What size spacers did u use?
          1991 318is S52
          1987 325i Vert
          1991 325i
          2011 e70 X5
          • Philo
            Ich esse kleine Kinder
            • 3334
            I recommend upping the spring in the rear. Something around 600 should do the trick. Or really, really roll the fenders.
            Also, i'm not sure what 'hardware' GC would be talking about. There is the spring, threaded sleeve, and adjustment collar. Not much as far as expense goes on their end for the necessary parts considering the price they charge for a spring. They should just throw it in, or be able to give you a spring that will work with the current items.
            -tim
            Originally posted by Jordan
            I like the stance
            • GThomas
              • Dec 2010
              • 869
              Just spoke with Jay from goundcontrol and he steered me away from changing the spring rates saying that it wouldn't make a difference. He said that the fenders need to be rolled more because even with a stiffer spring it would still hit. Just checked and the current rate is 480. So now i'm kinda stuck on what to do. The PO rolled the rears and told me that they are pretty much as far as they can go because the factory undercoating is caked on the other side. As for changing the hardware, GC said this is necessary because the springs at 480 have a 2.5 inch diameter and anything higher is 2.25 inch and requires new hardware to fit...
              So now i'm just kinda stuck wondering what to do...
              A.raise it up a bunch and hope it doesn't hit anymore.
              B.Put in a 5mm spacer and have it just hit the tire on bumps
              C.See if i can roll the fenders a touch more
              D.Change over all the rears to 700ish rates and buy all new hardware to accommodate the smaller springs.
              1991 318is S52
              1987 325i Vert
              1991 325i
              2011 e70 X5
              • sarcasmkillsme
                • Oct 2007
                • 255
                C. and D.
                • Hellabad
                  • 807
                  By the way, the GC 2.5 inch hardware can not only be machined to fit 2.25, they are pre-marked. This is how many people turn their street cars into race cars, that GC actually marks the parts to make it easier. So you don't really NEED to buy new parts, just machine them.
                  But I think you need to hellaroll the fenders no matter what anyways.
                  Jay
                  Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                  Ground Control Gallery
                  The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • IRON-E
                    • 16548
                    Along the lines of the OPs questions; I'm just getting into the coilover world and would like to know, what size height and spring rates people use for front and rear?
                    Fronts, I have heard that best for street and light track use is 400 rates and rears 650 rates since I'm carrying a set of heavy 12 inch speakers in the trunk. What do you guys suggest? The last thing I want or need is to bottom out on my first trial of spring rates...
                    Sorry to thread jack OP.
                    @IRON-E30 aka Edwin:D
                    • E30SPDFRK
                      • 5713
                      I just dealt with it. But depending on your tire size and how well they stretch you may need quite a large spacer. Et3 is just about flush wheel to fender for a 9 in the rear so if your tires expose the whole lip you probably would need to go more than that. If they run wide you could probably get away with smaller.
                      What shocks are you running?
                      Byron
                      Leichtbau
                      • Philo
                        • 3334
                        Spacer seems like a band-aid that 'kinda' works. Causing the tire to rub instead of the wheel is just moving the problem. I'm sticking with more spring rate, and maybe a little pull on the fenders if needed.
                        . . . Or you could just raise the rear up a bit.
                        -tim
                        I like the stance
                        • GThomas
                          • Dec 2010
                          • 869
                          Just ordered 700's from GC, i'll also raise it up a touch and i'm working on renting a fender roller so i can try and push them a bit more. Thanks for the help guys, ill keep ya posted on how it turns out.
                          1991 318is S52
                          1987 325i Vert
                          1991 325i
                          2011 e70 X5
