I upgraded the front calipers with the Wilwood set up from Massive, but now the clearance between the brake rotors and the tie rod end ( I have Meyle Tie Rods ) is only about 1/8".
I also had to cut a section of the brake shield right on top of the tie rod, the heat will damage the boot quick.
I was thinking to run a solid tie rod end, but not sure what will fit.
I was looking at these http://www.bakerprecision.com/auror7.htm
Any info. ?
Any info. ?
