Tie Rod Boot Filled with Fluid - is my Rack Bad?
  • Cloudbase
    • 1795
    So I fucked my (just replaced a few months ago) tie rods installing my new suspension. I got some lemforders to replace the old karlyns. (I know my spelling is wrong). When I cut the boot clamps power steering fluid just exploded in my face. The boot was almost completely filled with fluid. I don't remember that when I installed them last time. I'm assuming my rack is bad or at least a seal is. The car has 201,000 miles. Up until now the steering felt normal, but the fluid was a little low last time so I topped it off. I assumed it was seepage through the lines. Do I need a new rack?
    JOY IS AN E30...
  • george graves
    • 20003
    buy exactly this - not something like it...this.
    Originally posted by Matt-B
    • Cloudbase
      • 1795
      I should mention that all the rubber on the under side of my car is being replaced. If I was going to replace a rack this is a good time as the car is up and I have a little extra cash.
      If it's fucked then I don't mind. If I can use that stuff and get another 50,000 miles out of it then I will for sure. If it's just a band aid that will fail in 5K miles then I'd rather replace it.
      JOY IS AN E30...
      • I*Do*Werke
        • Dec 2010
        • 259
        e36 rack
        /thread
        ^M52B28^
        • Cloudbase
          • 1795
          Was thinking the Z3 option, but like to resolve how bad off my original one is.
          JOY IS AN E30...
          • JeST
            • 639
            I know from previous experience with my e46 (would assume the same for the e30). If the fluid is in the boots the rack should be replaced.
            Current: 1988 M3 - Henna/Black black alcantara
            Guten Parts + Service
            ... When you care enough to only give the very best.
            Previous:
            '87 S50 MTech 1 325is
            '07 DTM Audi S4
            '03 VF Supercharged M3
            '03 Lexus IS300 (615rwhp/512rwtq)
            • george graves
              • 20003
              Sounds like you want us to justify you wanting a new rack (BTW - I still don't think the z3 rack is the best option - but that's another thread) - have at at.
              Your current rack will implode and kill small children if you don't replace it asap. There.
              • Smelser
                • Feb 2011
                • 633
                Hey GG, You forgot to mention that little bunnies will die from the fluid seeping on the road, and when they go to try and drink it, SMUSH, right under the wheels of the guy behind him, who couldnt steer out of the way cause his fluid was low. And the Bimmer gods will strike down lightning on any one with there bare ass in the air if anyone does a band aid fix!
                Sry. just thought that was funny.
                sigpic1984 318i Total conversion to a DIRT race car.
                Check out our build on facebook @ www.facebook.com/brewstermotorsports
                • BraveUlysses
                  • Jun 2007
                  • 3781
                  My e36 rack has been doing this lately...I'm pretty sure it needs to be replaced.
                  • Brandon12V
                    • 1318
                    sounds like your seals are fucked. replace or rebuild... and might as well replace with a better lock to lock. a rebuild will usually cost about 50-100 less than a new rack. guess it's up to you whether that 50-100 is worth the better steering ratio. something to think about before you do this though...if you buy a new one you will most likely have a limited 1-3yr warranty. If you get a rebuild at say Rack&Axle, you will have a limited lifetime warranty.
                    Originally posted by Ryan...
                    It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                    • george graves
                      • 20003
                      I"m going to stop being helpful.
                      • Cloudbase
                        • 1795
                        dude hilarious. I should have been a little more clear. I'm not itching to buy a new rack, it's just real convenient to do right now. Let me ask you this, how bad was your rack leaking and low long has the stop leak lasted?
                        JOY IS AN E30...
                        • george graves
                          • 20003
                          Hasn't leaked a drop in about 5 years. I just pulled it out and replaced it with a '95 m3 rack while I was doing a suspension refresh. The best time to do a rack replace is when your motor is out - that's the easiest time to do it - dealing with bending the lines would be much easier.
                          • Cloudbase
                            • 1795
                            Cool, thanks...
                            JOY IS AN E30...
