here is a stupid question. how the hell do you adjust rear koni sports? I know your supposed to compress the shock all the way down and then turn the body but when I do this it doesn't seem to make any difference. They are MUCH softer then my bilstin HD's and I know they are not supposed to be like that. could they be blown out?
adjusting rear koni's?
And they could be blown, telling the mileage on them would help.
On a related topic I replaced my severely worn front Konis yesterday with new 1210 SA's (M-Technik/M3 valving). :D -
Jam a hanger in those holes at the top, and you'll feel the bump stop. Work it all the way down and take it out.Originally posted by nandoyou have to pull out the bumpstops and compress them to adjust them.
After that, you're good to go with adjusting.The BMW 318 is back. With a vengeance.Comment
I just adjusted mine (I'm pretty sure I did anyway).Originally posted by nandoyou have to pull out the bumpstops and compress them to adjust them.
When they are compressed all the way and you go to turn - does it have more resistance to turning then normal? Cause, that's what mine did. I let them drop maybe 1/4 of a cm, and the shock turned freely once more.
I always thought you turned slowly until some nut was engaged inside the shock - but nothing engaged - it didn't matter where the shock was - it seemed to get harder to turn, and I made them 2.5 turns stiffer. I'm almost positive I adjusted them, because as soon as I tested in a parking lot, my rear end broke loose a lot faster. :)- Sean HayesComment
you should be able to tell if they are adjusted when you pull the shock back out. with my konis on 100% stiff it's almost impossible to pull them back out from fully compressed. I don't think they get stiffer when you turn them, and yes you are actually turning a nut inside the shock.Comment
With the shock at 100% stiff, it takes a while for it to extend. You'll be pulling it apart for a good 5 minutes.Originally posted by nandoyou should be able to tell if they are adjusted when you pull the shock back out. with my konis on 100% stiff it's almost impossible to pull them back out from fully compressed. I don't think they get stiffer when you turn them, and yes you are actually turning a nut inside the shock.The BMW 318 is back. With a vengeance.Comment
Ok, mine were pretty tough to pull out. neato. 8)Originally posted by nandoyou should be able to tell if they are adjusted when you pull the shock back out. with my konis on 100% stiff it's almost impossible to pull them back out from fully compressed. I don't think they get stiffer when you turn them, and yes you are actually turning a nut inside the shock.- Sean HayesComment
What stiffness would you guys recommend running in the rear w/ these Konis. The springs I'm using w/ them are Eibach sports.
Do the rear shocks come shipped as full soft? I forgot to adjust them when putting them in, finally getting around to changing them :)
Thanks!
they come full soft, and you should drive about 500 miles with them on soft to break them in. the settings are all personal preference, I run mine at about 2/3rds in the rear and full stiff up front. you RWD guys might like different settings.Comment
