bilstien strut thread stripped??
  • ill4noreason
    • 2710
    Ok so i just took off my bilstien shocks/struts. Everything came off fine with the exception of one thread. I don't know if it was installed wrong or if it was bad threads from the factory. These came off my convertible which the previous owner had installed a lot new suspension parts. Then blew the motor 500-1000 miles later. So I guess I wanna know what you guys think.
    Anyone else have this problem? It's just weird that only one thread was screwed up of all the stuff i took off... I called bilstien they could care less and told me since I'm not the original purchaser they will not stand behind it even if it was there fault... Anyone re-thread these? Thanks for any and all help.
    My Multi car part out. Need a part? Pm me...
    http://www.r3vlimited.com/board/showthread.php?t=193051
    Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
    http://www.r3vlimited.com/board/showthread.php?t=215044
    Have you done business with me? If so leave me feedback here...
    http://www.r3vlimited.com/board/showthread.php?t=188307
  • gp.plus
    • 416
    I would just run a die over the threads and clean it up.
    • Hellabad
      • 807
      The threads are long gone. I think you may be screwed. It looks like someone used the wrong nut on the strut, and not the nut that is included with the Bilsteins.
      Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
      Ground Control Gallery
      The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
      • gp.plus
        • 416
        Or they ran it on cross threaded with impact gun, ignore my last post, now that I see the pic, buy a new one. Bilstein may put a new shaft in for you but time and cost vs new may not be worthwhile.
        I suppose you could try to rethread it for a smaller nut though.
        • KenC
          King of Kegstands
          • 14396
          You'll have to cut new threads with a die.
          Originally posted by Gruelius
          • rightcoastbias
            • 449
            Sweet this means the fronts H&R Races are off. :D I'm getting butterflies.
            On topic: I vote carefully run a smaller die across them.
            M52B28 OBD1 - G240 - S4.10
            Stuff for Sale: 24v swap parts
            • E30SPDFRK
              • 5713
              Should only be $10 to have Bilstein put a new shaft in it, call up their service department.
              Byron
              Leichtbau
                I would say that even if the threads weren't stripped that shock is bad. From what I see in the picture it isn't extended as far as the top shock, which would mean that it is bad.
                • M-technik-3
                  • 18946
                  Bilstein will not warranty improper installation but will repair the strut. Since you might be sending it in send them in pairs and have them re-valved to the say the springs you plan to use.
                  • ill4noreason
                    • 2710
                    these have at the very most 1,000 miles on them I doubt they are bad. but if they are then I really have a problem with bilstien. It seems like everybody loves them. Not me my car felt sloppy with these and the h&r races...
                    And how can a strut be bad with 500 miles on it? bad quality? it was installed the same as the other one. I don't know but I'll never buy anything from them again. Ground Control and Konis for me for now on...
                    • M-technik-3
                      • 18946
                      Sloppy maybe because the nut was not holding the strut firmly in-place.
                      • Brandon12V
                        • 1318
                        deception is in the picture. look where the threaded lock nut meets the strut tube on the bottom strut. they're probably extended the same length.
                        Originally posted by Ryan...
                        It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                        • ill4noreason
                          • 2710
                          i will look at them tomorrow when I get to my shop. and take new pic
                          • ill4noreason
                            • 2710
