length of rear coilover spring?
  • DJ W
    • Apr 2011
    • 185
    #31
    Originally posted by gverelli
    I have Eibach 5" 850lbs, 2" ID. Without the adjuster the car is tucking but rubs big time on 225/45/15
    if his rubs then the urs will to i strech 175/65/14 on the rear of mine and have plenty of space
    • penneroyal
      • 209
      #32
      Im going to run 800lb 5" spring in the rear ('88 325), will this tuck tire on 205/40/16 (stretched)? or should i go with a 4" spring? Will the 4" give adequate suspension travel? any help appreciated, thanks.
      THE ACURA TL PROJECT
      BUFF ENUFF? STYLE.OVER.COMFORT
      DURTY 3ER///STYLE.OVER.COMFORT
      • E30SPDFRK
        • 5710
        #33
        Why are all you people wanting such high spring rates? Honestly once you go past around a 600lb rear spring handling suffers, not to mention there there are extremely few shocks that can handle it.
        Byron
        Leichtbau
        • JPlue
          • Oct 2009
          • 203
          #34
          My 700 pounders are pretty bouncy in the rear with a Bilstein HD shock (which I think is only valved for ~300-350 lb spring rate). I wouldn't want any more without getting a shock that is made for it, I don't think you'd see much difference anyway.
          • penneroyal
            • 209
            #35
            What spring rate and length are you running? From what ive been reading people are running 650-850 rear spring. I'm getting the re-valved koni's to handle the high spring rate.
            • 4ce30
              • Feb 2006
              • 2762
              #36
              I run 500/750, great for drifting not soo great for daily.. i would recommend 375/450 i really liked that setup even with bilstein sports..
              • mo diesil
                • Jan 2011
                • 275
                #37
                Originally posted by chop_suey
                will a 225/50/15 rub on an early model with a 5in 700/750 lb spring? Or should i step up to a 6in spring?
                no you may even still have wheel gap
                • grippymonkey
                  • Jun 2011
                  • 759
                  #38
                  BUMP for more pics of late model E30's and info on your spring length and rates
                  GRIPPY'S*GARAGE
