front strut mount dust cap
  • davem
    • Jun 2010
    • 705
    Hey guys just threw in new strut mounts and the plastic dust caps (w/ bmw logo) from the old strut mounts don't fit well with the new strut mounts. It's like the hole in the new strut mounts are larger, so the dust cap doesn't tighten up.
    The new strut mounts are Lemforder brand. Car is a '91 325i.
    Anybody know what's up? Do I need different ones?
  • blefevre
    • Dec 2008
    • 4287
    Yep, I had the same problem. BMW makes two different sizes, get the other one.
    - E30, DSM, Golf R, Mazda 3 Skyactiv
    • davem
      • Jun 2010
      • 705
      Hey look at that you're right:
      06 Covering cap D=32MM 2 31311139453 $1.48
      06 Covering cap D=28.5MM 2 31331124335 $1.71
      • chrisca70
        • Sep 2013
        • 239
        As a thread revival, I had the same issue and tested both caps and none of the sizes work, The current OEM strut mount diameter hole is 31mm. So I added a couple of mm to the original 28.5mm caps by adding electrical tape until I got a snug fit. This applies to all E30s models (except XI) as the struts are the same.
        • Tzantushka
          • Nov 2018
          • 389
          Yep that's what I did.
          For a low risk functional part still holding up fine.
          E30 320i vert
          But daily drive is Volvo V60 Polestar
          • AndrewBird
            The Mad Scientist
            • 11898
            I 3D printed a set and designed it with an o-ring groove. The o-ring provides the friction to hold it in place.
