adjustable spring companies?
  • sdub
    • May 2011
    • 220
    i'm looking to put adjustable coilovers on my car and was wondering what if any companies make adjustable springs (just springs) so i can go low low low.
    anybody with experience/ride input appreciated.
  • Fusion
    • Nov 2009
    • 3659
    I don't think that's possible. There's no movable/adjustable parts to a spring.
    You could get drop hats though, that's probably the easiest way to drop.
      Ground Control is going to your best choice.
      • sdub
        • May 2011
        • 220
        ya i'm talking cheap a$$ tuner style coilovers. I would just cut them but the rears make it pretty sketchy as i'm sure you all know.
        anybody else besides ground control?
        • M-technik-3
          • 18946
          remove em
            • 34839
            Wooden blocks?
            Ebay junk?
            Ground Control? (is $400 really too much?)
            Those are some choices
            • grippymonkey
              • Jun 2011
              • 759
              save up... mow some grass... sell some crack
              get some GC's
              GRIPPY'S*GARAGE
              • mr.vang
                • 4371
                civic ebay coilover fits..its only $40..you can go dangerously low but you will be bouncing around in the car
                • Mossman
                  • Apr 2006
                  • 1961
                  this is true only if your shocks/struts aren't up to the task of controlling a stiffer spring. A spring is a spring is a spring, it's job is to compress and return to its original position and the ebay springs do that too, some are longer than others, some are stiffer than others, but a spring is a spring. Aside from longevity, finish quality, rust resistance and consistency from spring to spring and batch to batch (whether actual rate matches advertised rate), there are no difference between how a GC supplied eibach racing spring and an ebay sourced civic coilover racing spring "works". The adjusters on the other hand are chintzier, and aren't matched to the front strut diameter or the rear spring location nubs when you buy a universal kit, but that can be remedied with some ingenuity.
                  • mr.vang
                    • 4371
                    the front adjuster fit perfectly and the rear you will have to open up the upper spring seat.
                      • 34839
                      nobody spending $40 on springs is going to spend the neccesary money for good strut inserts and rear shocks.
                      • mr2peak
                        • 2388
                        $360 saved leaves you some good money towards some billies. MR2 guys have been using the miata coilovers for years. Anybody actually tried these on an E30?
                        Edit: on second thought I'm not sure how the rear would work as they are designed as a coil over shock setup
                        Drive it hard. Maintain it well.
                        A Topless Memorandum
                          • 34839
                          springs that cheap have to be made of sub-par materials. you can't even have something powdercoated for $40.
                          • Jb325is
                            • 2137
                            Are you planning on shortening the struts? Thats the only way to go "low low low." I bought some sleeves from a1 racing that were 90/pair with adjusters and upper perches, and designed to fit over strut housings. Check my e34 build in the project forum for details. Its hard to half ass coilovers on the front of an e30
                            - '88 m54 coupe
                            <3
                            • sdub
                              • May 2011
                              • 220
                              ^^ I will def check that out.
                              i was just curious about companies that made adjustable ones, not wanting to use super cheap springs that was just as an example of what i had in mind.
                              but i guess GC will be the ones, I coulda swore that H&R made an adjustable set? i must be mistaken.
