Why is there space between my front spring and the strut mount/spring seat?
  • ScHpAnKy
    • 1573
    Got new strut assemblies because the collar nuts were frozen onto my other 4 ones, got KYB GR-2 cartridges and put some SPAX springs in the front of my euro build, however - when I put the strut mounts back on there, there's still a good 4-5in of distance between the top of the SPAX springs and the spring seat, even with compression I'd need some sort of spacer to crank it down so that the spring isn't rattling around on the cartridge... what the hell gives? I haven't done this drastic of a drop (3") on an e30 before, but I can't imagine that this is the first time somebody's come across this?
    When it's mounted on the car, it'll likely compress and seat, but I'm worried that the spring will unseat in adverse suspension conditions... I
    I even went so far as picking up two regular m12x1.25 nuts and tried to thread them on... what's odd is that it threads about 2.5" down the shock cartridge and then completely binds up and won't travel further - this is so frustrating.
    91 318i | 87 535iS
    • 34844
    put it on the car, there's space because the spring is much shorter. it's not going to rattle around, it's going to sit on the spring.
    • ScHpAnKy
      • 1573
      so you're positive that even though the spring rattles around on the assembly because it doesn't mate to the spring seats, when the car is dropped on the springs it'll sit on the spring seats and never come undone? It's a little worrying that the springs have so much play when they're free-standing.
      91 318i | 87 535iS
        • 34844
        yes. this is common with drop in springs, especially ones that are meant to dump the car.
        • ScHpAnKy
          • 1573
          good to know, I feel a lot more confident about my front setup now, thanks!
          91 318i | 87 535iS
          • ak-
            • 12422
            Hello,
            I am also here to build your confidence in saying that this is normal for shorter springs like yours among others.
            It ain't going anywhere.
            1991 325iS turbo
              • 37833
              If you were to jump your car at high speed, say 6 feet off the ground, the spring may move around though.
              Keep that in mind.
              Grover Beach, California
              BimmerHeads.com
              • CabbE30
                • Aug 2009
                • 2358
                Keep that in mind.
                Some people do it..
