Body Roll on Stock Sway Bars
  • aTron12
    • Nov 2009
    • 98
    Originally posted by blefevre
    Yep, most springs should last a very long time, no surprise there. I wouldn't expect very flat handling with those springs though, regardless if you get the eibach sways. They aren't that big. They are 20/16mm. The factory is 20/12 for most cars. Why not get the IE 22/19 or suspension techniques. You are going to need a beefy bar to make up for the crazy soft springs you have. And don't forget to reinforce the rear if you insist on going big bars/soft springs.
    All good info to take into consideration. I want a balanced setup so I won't be going bigger in one area to make up for inadequacies in another. That is a recipe for disaster. Are the Eibach's really that bad? They seemed great for a good year or so.
    • blefevre
      • Dec 2008
      • 4287
      The eibachs have really weird (low) spring rates. Do you have the pro-kit or their "race" kit?
      H&R sport, vert front bar, ix/m3 rear bar is a very balanced setup. However it doesn't lower the car that much. It is very good for DD duty.
      - E30, DSM, Golf R, Mazda 3 Skyactiv
      • LJ851
        • 7919
        E30 spring rates
        I have a vert front bar for sale if you are interested.
        Lorin
        The M30 is God's engine.
        • aTron12
          • Nov 2009
          • 98
          WTF, why would Eibach make a performance spring at a lower rate than OEM?! That makes no sense. More of a rhetorical question.. but shit man, that's weird. They claim to reduce body roll in comparison to stock springs :-/
          PS. I have the Pro-Kit.
          • Fusion
            • Nov 2009
            • 3659
            Is there a high(er) rate spring with a decent drop like 2.4in?
            Iirc, H&R race are 4cm/1.6in
            • Jaxx_
              • Dec 2009
              • 1880
              Originally posted by Sagaris
              I am a fan of softer springs with stiff sway bars. You still get good forward/rear weight transfer and comfort but the stiff sways help keep the tires from being overloaded from lateral weight transfer.
              Remember that sways are torsion bars -- and you maximum spring rate can only be 200% of what one of the springs is. I think your thinking isn't always practical. Especially if you're looking for quick response in your steering.
              Originally posted by Stoner Sam23
              I have been told that lowering springs on our cars preloads the sways making them less effective. Adjustable sway bar links should correct this and help body roll. I have not done this becuause it doesnt add up to me (maybe the front). Just a theory I am passing to you.
              i don't see how this is possible either.
              If the springs are near their end of life, yes you will get more body roll. That shouldn't be for a long time though, but I did not design eibach springs so I'm not sure what they designed to.
              Sure, you can slap on huge sway bars and you will have less roll. You will need to reinforce the rear so you don't tear your bar off as it will be doing all of the work to make up for the soft springs.
              I still recommend stiffer springs as it will also reduce dive in under braking and lift during acceleration which will also help handling. Sway bars will not do this.
              life of automotive springs is long. like seriously long. Unless they've been under some massive heat or some serious load for a long time, they shouldn't deviate significantly for many years.
              again, the big bar can only provide 200% of one "soft" spring.
              correct swaybar selection can help acceleration or braking when cornering.
              I run a factory front bar and a factory 12mm rear sway (none with 318) and my car is super neutral with a hint of oversteer if you are aggressive on slaloms. It's perfect for a 318.
              • aTron12
                • Nov 2009
                • 98
                So I looked further into swapping springs even if there is an issue with bushings/bars, etc. Here are some specs. Looks like the H&R aren't that much different height wise:
                Eibach Pro-Kit: 1.0-1.5"
                H&R Sport: 1.25" front // 1.25" Rear
                Spring rate:
                Eibach: 102
                H&R Sport: 180
                Just thought that was interesting...
                • paresmi
                  • May 2011
                  • 31
                  Buying H&R race will reduce your body roll much more then getting bigger sway bars.
                  I can't say anything for the sway bars but I can tell you H&R races on their own almost eliminate the need for sway bars. That's a little exaggeration but I'm hardly getting any roll on stock sways.
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    you're not driving it hard enough.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      I reiterate
                      • Holland
                        • Nov 2008
                        • 7212
                        Springs should ALWAYS be your main form of anti roll. Swaybars should be support to balance things out. OP Bilstien HD's are meant for stock ride height, sport shocks should be used with lowering springs. I agree with using H&R race, as they are rated much better for Bilsteins.
                        Originally posted by DEV0 E30
                        • aTron12
                          • Nov 2009
                          • 98
                          The H&R race slam the car and throw off the camber, don't they?
                          I'm thinking about the sports because I'm not tracking. What's your thought on the sports?
                          • paresmi
                            • May 2011
                            • 31
                            Spent the last two days driving hard in the canyons and there wasn't any point where I could think there was a significant amount of roll.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              It's more outside the car... ;)
                              • paresmi
                                • May 2011
                                • 31
                                Yea I need to track it to really say I drove it hard. still doesn't look like much roll especially compared to stock. That could also be the reason why I feel the HR races have "no" roll cause I'm comparing it to my experience with the stock springs. Awesome pic examples
