How to reinforce rear shock mounts for true coilovers in the rear?
  • xikyle
    • May 2011
    • 526
    So, ive been looking at getting a set of Gaz gold's but i realized that e30 has a separate spring perch from the shock mounts. how would somebody go about reinforcing the shock mount so it doesn't get a hole punched through it by the coilover springs??
    what is the easiest way to get-er-done?
    Originally posted by ApexGoblin
    well make sure your priorities are straight... e30 first :up:
  • bimmerteck
    • 762
    Tie the roll cage into the rear shock mounts. ;)
    • xikyle
      • May 2011
      • 526
      roll cage was a little bit more then i was thinking.
      is there any way to do it with out needing an entire rollcage?
      • Hellabad
        • 807
        Not that I could ever think of. Brace it to what? There isn't even anything to brace it to.
        You could probably get by with a welded four or five point rollbar.
        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
        Ground Control Gallery
        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
        • xikyle
          • May 2011
          • 526
          bump because im still not satisfied...
          • kronus
            • Apr 2008
            • 13032
            You want to box in the upper strut mounts completely with some pretty decent metal, and get a weld-in strut brace between the two towers, tie it in to the trunk floor.
            The stock upper mount area is pretty thin metal with a big hole in it for the RSM, that should be doubled up and secured down to the trunk floor and inner wheel wells.
            cars beep boop
            • xikyle
              • May 2011
              • 526
              YES! finally! thats what i was looking for! what kind of front bumper are you running? i like that (in your sig)
              • kronus
                • Apr 2008
                • 13032
                euro bumper, early euro valence, Pfeba lip
                cars beep boop
                • bmwguy325is
                  • May 2011
                  • 1263
                  Why would you want to do that? But the above answer works. Just seems a waste.
                  sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                  The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                  • SumoE30
                    • Aug 2011
                    • 4
                    why run true (race) coilovers and not race requiring a cage?
                    • xikyle
                      • May 2011
                      • 526
                      good question... money saving, 'till i can afford cage.
                      • xikyle
                        • May 2011
                        • 526
                        what?!
                        • kronus
                          • Apr 2008
                          • 13032
                          what?!
                          do...you... not believe me?
                          old pic, eventually the lip paint faded to be closer to the rest of the car:
                          cars beep boop
                          • xikyle
                            • May 2011
                            • 526
                            oh lol gotcha, love the look of the euro bumpers and valance, its noice brah
                            • einstein57
                              • Jun 2007
                              • 10780
                              Doesn't mason sell a triangular reinforcement brace?
                              www.gecoils.com
