No PS after M50 swap with 98 M3 rack.
  • N2MYE30
    • Oct 2007
    • 5536
    While my engine was out...
    I installed a 98 M3 rack with new inner and outer joints.
    Original PS res from my M20 (~3 years old). Installed correctly on the e36 arm.
    The engine has 102K on it (im assuming the same age on the pump).
    The hoses are mismatched e30/e36 lines with no noticeable kinks in the lines.
    New ATF.
    Turned the steering left to right a few times to bleed.
    No power steering!!! :hitler:
    I have put ~30 miles on the car already with no signs of it getting better.
    No noises at all.
    Res isnt full of bubbles and res is full.
    No leaks.
    I verified my connecting lines with my buds 24V swap...same.
    How can I diagnose to see if my PS pump has failed?
    How can I diagnose to see if my rack is bad?
    Anything I am missing?
    COTM
    • 37834
    If there's nothing leaking from the lines or rack I'd bet on a bad pump.
    Grover Beach, California
    BimmerHeads.com
    • N2MYE30
      • Oct 2007
      • 5536
      I guess ill try to get a pump from the pnp. Last resort is going to be the rack since I did just put it in...without anything in the way!
      COTM
      • Hellabad
        • 807
        There is a relief valve in the PS pump that can get stuck open.
        You can take it apart and clean it, or bang on it. (kidding)
        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
        Ground Control Gallery
        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
        • Unearth078
          • May 2008
          • 2623
          Wait... thats a problem? jk. posting so i learn more once you find a solution :) plan on putting power steering in my verts 24v swap.. eventually.
          Originally posted by Lof8
          4 doors allow you to transport more whores.
          therefore, their value is much greater.
          Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
          • N2MYE30
            • Oct 2007
            • 5536
            Any more info on this? Do I need to remove the pump to do this?
            COTM
            • N2MYE30
              • Oct 2007
              • 5536
              Just an update. It wound up being the ps pump. My plumbing was correct. Life is good. :)
              COTM
