How to tighten up steering?
  • blacksport325
    • 231
    I've driven a few e30's and mine is by far the worst in terms of steering. It feels like there is 'too much' power steering, its incredibly easy to move the wheel at low and high speeds, i'm looking to tighten it up a bit if thats possible. I have new tie rods, no PS leaks/noises, the steering knuckle and rubber 'doughnut' look good and don't make any noises either.
  • LJ851
    • 7919
    Install E36 rack
    Lorin
    The M30 is God's engine.
    • blacksport325
      • 231
      Yeah, I was hoping to avoid that, I can get a rack fairly cheap but those hoses are what kills it, unless I can re-use my hoses from the e30...I think it's just somewhat weird my steering is too easy to turn, I was thinking of deleting the power steering, but I may regret that.
      • LJ851
        • 7919
        I reused my stock e30 hoses. You only have to tweak them a little. What is your front toe set at? If you are towed out it is a lot easier to steer and less stable in a straight line at speed. E36 rack is really nice anyway, makes the car feel 10 years newer.
        Lorin
        • CW325
          • Jul 2011
          • 1434
          disconnect the ps belt and see if you like it befor you delete it
          • bernzpeed
            • 3917
            Z3 rack
            89 E30 S52
            Transaction Feedback.
            • blacksport325
              • 231
              My toe is a bit out of spec, I've been meaning to get an alignment again, just lazy, I didn't think this would affect turning stiffness too much, perhaps it's time to get an alignment. Thanks for the replies guys, i'll look into picking up an e36 rack if I can re-use my hoses. I know the local junkyard has some e36 318i's, I need to figure out if these are different than my current rack before I grab one.
              • e30boarder
                • Jul 2010
                • 41
                replace your bushings with polyurethane... stiffened mine up a lot
                • LJ851
                  • 7919
                  Another option would be to lower your tires air pressure 10 or 15 pounds.
                  Lorin
                  • BrettsE30
                    • Feb 2011
                    • 306
                    Steering guibo worn?
                    I need your obd1 parts! Harness intake ecu etc.
                    E30 Your Daily Money Pit
                    • immajackuup
                      • Dec 2010
                      • 1132
                      • blacksport325
                        • 231
                        Looks like it's in good shape to me with no cracks or anything, I'm going to get an alignment this weekend hopefully, i'll let you know if bringing the toe into spec fixes it.
                        • Tu0cs
                          • Apr 2011
                          • 11
                          I had your exact problem, the steering was quick and too light. I replaced my steering rack to the e36 one, and now my steering is heavier and more bmw like. Took me a week to install the new steering rack, but got it done!
                          • ubernasty
                            • Jan 2009
                            • 2749
                            your car looks a lot like mine. were you the guy i met at gutenfest?
                            • acolella76
                              • 2950
                              isn't there a little nut on the bottom of the rack he can tighten so there is more drag? or is that only on e36 racks
                              -Alex
