OP, I'm thinking its one or more of the following:
The sway link is loose, broken or not connected.
The strut mounts aren't tight enough.
There's a possibility too that your subframe could be loose. It's held on by four bolts. Check all of them qnd make sure they are nice and tight.
There is also a chance that the ball joint for the control arm isn't all the way tight.
Last thing I can think of are your steering rack bolts. there are two. make sure both of them a very tight. They are through bolts so they have a nut on the back side.
Good luck
Taylor
Good luck
Taylor
